Old 05-27-2010, 10:14 PM
98sst's Avatar
98sst 98sst is offline
Vehicle: 1998 Dodge ram 1500
Trim Level: SS/T
Rep:883
I tried it. No reading from it with the key on. Ugh.. Lol. I see three wires on the side. Black in front. Red. And then purple. I know it's the right thing. Got myself a CEL now cause dad pulled it.
Old 05-27-2010, 10:26 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Smile
Nice job writing that up, information like that is what makes this such a great forum. Reps for you.
Old 05-28-2010, 03:52 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
not sure if I mentioned this in the post, but, was your truck at operating temp?
And, did you get the tester in there far enough? Its kinda a flakey connection, but, thats how the service manual said to do it. You kinda have to push the testers in pretty hard and hold them there.
Also, since he took it off, it will definitley need adjusting.
And, just unplug the battery, it should clear the code once everything is hooked up again. Mine did the same thing since I unplugged it.
Also, thanks for the rep guys Just trying to help out some fellow 5.9 guys.
And, this should be the same for a 5.2L. Not sure if I mentioned that either. But, they're practically the same engine/fuel injection system.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 05-28-2010, 09:51 AM
98sst's Avatar
Trim Level: SS/T
Rep:883
All he unplugged was in fact the plug, you believe it will need adjusting then?
I'll try again after school. I have an analog voltmeter... lol it's hard to read for .5 to 1.5 volts.
Old 05-28-2010, 11:04 AM
Rep:210
oh...no...nevermind. I thought you said he completley removed it from the TB.
But, I used a digital one, may be easier with an analog, though.
and after school? Ouch, we're out already. Not that I'm bragging or anything
Old 05-30-2010, 06:26 PM
red03ram360's Avatar
red03ram360 red03ram360 is offline
Vehicle: 2003 dodge ram
Color: pr4 red
red03ram360 is on a distinguished road
i could only adjust mine to .8 volts, do u think if i got a new tps it would make any difference, like being able to adjust it to a full volt at closed throttle? id imagine because its a high movement part that it would wear the contact points between the seat and the sensor, i am just curious if i put a totally new one in would i get a bit more snap out of ye ol'360.
Old 05-30-2010, 10:05 PM
Rep:210
you have an 03 with a 360? Wow, thats rare. Might be worth something someday...lol
But, you want it as close to 1 volt at closed throtte as possible. Mine was only at .67 since it has 143000 miles on it...haha. So, you are closer than me.
Old 06-03-2010, 12:47 AM
amermuscle's Avatar
amermuscle amermuscle is offline
Rep:35
amermuscle is on a distinguished road
so would i need a new one if i had 135xxx miles on mine ?
airgap ,SCT tuner,52mm fastman,pacesetterlongubes,magnaflow cats,K&N cai,viper cowl hood,1.7 HS
Old 06-03-2010, 12:49 AM
98sst's Avatar
Trim Level: SS/T
Rep:883
Not necessairly, I'd check the numbers, try to adjust it and go from there.
Old 06-03-2010, 03:01 AM
hunTer06's Avatar
hunTer06 hunTer06 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Rep:60
hunTer06 is on a distinguished road
Send a message via MSN to hunTer06
great write up! wish I was home...I would check it out on my 5.2.
