Old 07-29-2010, 12:26 AM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
Originally Posted by toddrod View Post
Hey I tried out your tip and now i've got a check engine light. how did you get a reading with the voltmeter. I checked my chiltons and the only way I get any reading is from the electrical connector. and how were you able to twist the sensor without taking off the torx screws. I only loosened them and the tps barely moved. I was being delicate, not to sure what happened lol. some more info would be nice
You unplugged the sensor didn't you? haha. The check engine light will go off after a few key cycles.
But, you stick the probes from the volt meter into the back of the plug (where the wires go in). You have to be pretty aggresive when pushing them in there. Also, you just loosen the bolts and twist it gently. It doesn't move much...but, every .0x of a volt will make a performance difference.
Some people even drill them out for more movement, but, I haven't been brave enough to try that yet.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 07-29-2010, 09:21 PM
toddrod's Avatar
toddrod toddrod is offline
Vehicle: 2001 Dodge Ram
Color: Yellow
Rep:55
toddrod will become famous soon enough
Thanks, for the info, I ended up disconnecting the battery and it reset the program, I'll have to give it another round and let you know how it fairs
Old 07-31-2010, 09:38 PM
Mac's Avatar
Mac Mac is offline
Vehicle: '99 Dodge Ram 1500 4x4
Color: solar yellow
Rep:83
Mac will become famous soon enough
Please do toddrod, I'm watching this thread with interest.
Old 07-31-2010, 10:45 PM
carrayz's Avatar
carrayz carrayz is offline
Vehicle: 1999 dodge ram 1500 ext cab sb
Trim Level: laramie slt
Color: silver
Rep:21
carrayz is on a distinguished road
never thought to do that.going to try it.very nice job on the info thankyou!!!
Old 07-31-2010, 10:56 PM
Ramrob Ramrob is offline
Vehicle: 1999 Dodge Ram 1500 5.9L
Rep:75
Ramrob will become famous soon enough
I should have tested it before I messed with it to see the difference. 03 1500 5.9 120,000 miles. I got .71 closed and 3.85 open.
Old 07-31-2010, 10:57 PM
Rep:75
Drill what out?
Old 08-06-2010, 09:41 PM
toddrod's Avatar
Color: Yellow
Rep:55
Hey all I'm back. Okay, tried this again and I'm having no luck. The voltmeter reads 5.10 with the throttle closed, key in "on" position. I open throttle and no change in readings. I loosened the torxs and tried moving the TPS and get 0.00? I read the chilton's and it says if you get an inaccurate read (normal being 0.5-1.5 throttle closed, 3.5-4.5 wide open) replace the sensor. Here's my next question, if the tps is faulty and needs to be replaced shouldn't I be getting a check engine light on the dash? Any ideas?
Old 08-07-2010, 02:11 AM
Rep:210
If you're getting a reading, then, no, it won't throw a check engine light. The only time it will throw a check engine light is if it does nothing.
Also...I think you must have the wrong wires, because, it wouldn't run if that was the case, it would be full rich at idle.
Try switching the wires that your testing in the plug.
Old 08-07-2010, 07:39 PM
Quiet Lunatic's Avatar
Vehicle: SRT-10
Rep:434
I did it & loved it! It was an easy checkup / adjustment and I really appreciate the tip. I would never have thought to look at that. A little trick I used to make it easier was to unfold a paperclip and use it to stick into the wire connections and then use my alligator clip attachments for my volt meter to hook to the paper clips. I was able to adjust the TPS from .6 to .74 in the closed position!
Old 08-07-2010, 10:59 PM
Mtx's Avatar
Mtx Mtx is offline
Vehicle: 97 Dodge 2500
Trim Level: 2500 4x4
Color: hunter green
Rep:16
Mtx is on a distinguished road
ill have to look into doing mine. cant be to different from my old formula TPS
