AC not working - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Heating & Cooling
Old 05-19-2010, 11:51 PM
hockeyplaya13's Avatar
hockeyplaya13 hockeyplaya13 is offline
Vehicle: 2002 1500 Quad Cab SLT
Color: Atlantic Blue
Rep:22
hockeyplaya13 is on a distinguished road
Default AC not working
Not sure what the issue is here. I've taken it to the stealership as well as our local mechanic that we usually use, and they both kind of gave us a . They recharged the air compressor and refilled it with refridgerant, and it worked for a few weeks, but then slowly died again. So they filled/recharged it again and put a UV dye in it this time so they can tell where the leak is, but they know it's not in any of the hoses in the engine bay because they vacuumed it all out through one of the hoses and there was no leak. So they think it's the evaporator. I have no idea a) what that is or b) what that does. All I know is they said it's ~$800 to fix it. So I was wondering if there's a cheaper solution. Is it something I could do myself? Or is it so involved that I'd be better off just forking over the cash?
Old 05-20-2010, 12:00 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
The evaporator is the part in the cab that gets cold and the fan blows air through.
I'm afraid the only DIY for this is roll the windows down.
You might be able to get one from a salvage yard, but if your not familiar with AC systems, installing this is likely best left for the professionals. You could do all the prep work, and leave the final connection for them, but a salvage evaporator is risky at best, unless the salvage yard was able to certify that the unit came from a vehicle that was charged, and they had to evacuate it during salvage. We have a salvage yard here that does that, but many don't.
Good Luck with your repair.
brad
Interested in one of my mods?
Old 05-20-2010, 11:24 AM
Rep:22
Ok thanks. I guess I'll leave it up to them then. But hopefully that isn't the issue
Old 05-20-2010, 11:32 AM
Resident Technician
Rep:1915
If a dye test hasn't revealed a leak and you keep losing refrigerant, the evap or a connection to it inside the heater box is the most likely problem.
