Old 05-20-2010, 10:52 AM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Default Preferred 2010 Laramie Level Kit?
I've searched and seems like the 2" leveling kits are hit or miss on the Laramie "shake" issue... my question is what(quality) kit is the recommended path for the Laramie specifically? I do not care to raise the rear unless it is necessary to keep driveline alignment.
I do know we have at least one confirmed success story on a Silver Laramie recently for the aluminum spacers. Has anyone used ReadiLift's 4-corner kit?
http://www.fourwheeler.com/techartic...kit/index.html
How about SuperLift?
http://www.superlift.com/Catalog.asp?V=150&P=40019
I do know that KORE plans on releasing a spacer kit at somepoint and there are rumors of a Mopar kit - my parts guy and I called the Mopar Support Center yesterday(think its in Atlanta GA) and they do not know of a 2" kit or leveling system coming for the 4Gen Rams... no part numbers in their system. Don't know if this will be coming or not.
Sorry for posting here but this forum looks like it gets 8-10x more readers vs Suspension forum. Thanks for any help/guideance.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 05-20-2010, 11:30 AM
MTtruckr's Avatar
MTtruckr MTtruckr is offline
Vehicle: 2009 Ram 5.7L
Trim Level: Big Horn Package
Color: Stone White
Rep:50
MTtruckr will become famous soon enough
I posted in the "Wheels and Lifting" section on a mopar kit. Check it out under "Mopar level kit...it's real!" It is made by superlift.
Also, if you have the Auto 4 wheel function that is an option on the Laramie's you cannot level it out...so I've been told.
Personally, I like the idea of adding a spacer in the rear to get a tad bit of height and raise the back end to help counter some sag if you have a load.
BDS 6 inch. Fox 2.0 rear. Toyo MT 35x12.50x18. Yukon 4.56's. Detroit Truetrac. Mufflex 18. Airaid CAI.
Old 05-20-2010, 03:02 PM
Rep:44
Default Yes, thats the one they see but has no detail on the
PN. Not sure when it will release, the rep yesterday thought it odd that there was no detail. I have never chased Dodge parts so no clue myself.
On the Laramies, I spoke with a tech at one of the lift companies whos seen the vibration/shake on their kit. His only advice was don't use 4WAuto... didn't seem to be concerned outside of that. I haven't chased this enough to determine if its limited to that mode or not.
