MOPAR DECALS
Old 05-20-2010, 12:40 PM
robertdotcom robertdotcom is offline
robertdotcom is on a distinguished road
Default 2004 Dodge Ram 4.7 Engine blowing Antifreeze out Exhaust
My 2004 Dodge Ram with the 4.7 engine (2 wheel drive) is running very bad and blowing antifreze out the exhaust. I was told it may have a bad head and the guy who looked at it thought it was the passenger side. The truck only has 75K miles on it so I was wondering if it was worth fixing or replacing. The oil was VERY dirty when I bought it and it ran bad then but only got worse as it was driven.
I build websites and just started learning about these trucks so any advice is appreciated!
Old 05-20-2010, 02:40 PM
Rep:1625
I see this is your first post, welcome to the forum! We're glad to have you here! I'm not the guy you're looking for, but hang in there, this forum is filled of plenty of other knowledgeable members
Old 05-20-2010, 02:56 PM
Resident Technician
Rep:1915
Get it diagnosed first. if it's just one head or head gaskets, it's worth fixing. If the "guy who looked at it" isn't sure what the problem is and to which bank it's on, you need a new "guy".
Old 05-21-2010, 06:27 PM
tmansram's Avatar
tmansram tmansram is offline
Vehicle: 2002 Dodge RAm 1500 Quad Cab
Color: Blu
tmansram is on a distinguished road
Sounds like a head gasket. I had the same problem. Had a quote for $1800.00 to get the heads rebuilt. Other mechanics suggested replacing the motor, saying the 4.7 isn't worth rebuilding. $3200.00 for a Jasper motor. Either way money has been tight. I put a $40 bottle of BARS Head gasket sealant in the motor. It sealed it up with no coolant loss in 6 months. It may be living on borrowed time....but...
Old 05-21-2010, 09:56 PM
Resident Technician
Rep:1915
Sounds to me like a lot of "mechanics" are intimidated by the 3 timing chains in the 4.7.
Old 05-30-2010, 03:56 PM
Mr Refney Mr Refney is offline
Mr Refney is on a distinguished road
Default Successfully repaired at home
I recently replaced the head gasket in my '02 after getting coolant blowing out of the exhaust. My dad was a mechanic for 15 years, and still has his tools, so I've got experienced help on hand. The best thing I did was find the official Dodge service/shop manual online. 2000 plus pages of diagrams for every part or repair you can imagine. I paid $10 for a pdf file, just printed out everything I need for that repair.
You can take off the top rail at the front of the engine compartment, which makes in even easier to work. Radiator was removed entirely and replaced, and I took the alternator, a/c compressor, and power steering loose and just swung them out of the way with bungie cords.
The head bolts are not TTY on this engine, though a lot are on newer vehicles. The service manual has a procedure for testing the old bolts for stretching, i.e. put a straight edge on the threads, make sure they all touch. Mine were fine. Also, there is a special tool for holding the chains in place which I didn't have. I made one out of a donut shaped piece of plywood with metal pins stuck through it in the appropriate spots. Worked great.
I had my heads tested and resurfaced by local shop, and then bought some quality gaskets. So far, I've put 10K miles on, with no issues.
I bought it with 103K on it, and the previous owner had apparently tried to fix his coolant leak my dumping in some radiator or head gasket sealant, which then proceeded to ruin the radiator. My local shop couldn't even core it out it had so much gunk in there. So, I'd say avoid the temptation of doing that and expecting the problem to go away.
Old 05-30-2010, 06:23 PM
Just remember : antifreeze is extremely harsh on engine bearings . You may beable to fix it but you won't know what other damage has been done .
Old 06-07-2010, 08:39 AM
GaryGtx GaryGtx is offline
Vehicle: 2002 Dodge Ram quad cab 4.7l
Color: light blue
GaryGtx is on a distinguished road
hey do you happen to have that web address were you got te pdf file? Im gonna need that very quickly! thanks
Old 06-22-2010, 11:06 AM
fixitfirstime's Avatar
fixitfirstime fixitfirstime is offline
fixitfirstime is on a distinguished road
Best advise is buy a chrysler service contract when you buy a 4.7 truck, The water pump and heads will be paid for then and you can run the wheels off it! I bought one with 71k on it and water pump failed first then the heads turned up warped. Antifreeze loss and mis fire cold were the symptoms. The Chrysler service contract basically makes it where the dealer can "be" the underwriter so you get new parts & customer driven policies rather than junkyard insurance company alternatives. For example if there are multiple items that are covered on powertrain on the same visit...you pay only one deductible for all the items. I ended up with reman. mopar head and cams...and apparently they had superceded to HO Jeep stuff cause the complete head number had the HO cams and the castings even said HO on one corner.
I like the extra 35 horsepower!
4.7, engine trouble, ram
