Old 05-20-2010, 04:07 PM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Default What is the "clunk" sound/feeling after a complete stop?
On my truck - if I coast to a stop I get a small clunk sound/feeling a few seconds after stopping, does this even when I roll a few yards and then stop again. Is this the trans shifting to 2nd and then back to 1st at rest? Not really annoying or anything, but makes me curious if its normal or if I need to get it checked... truck has 150mi on it, 48hrs old.
Thanks for any feedback.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 05-20-2010, 04:21 PM
Rep:2657
Mine does it too, i now have 20,000 miles on it, its barely noticable, but, its there
Its almost like a brake part is hanging up & then finally closing on the rotor after about a second
Old 05-20-2010, 05:01 PM
CustomShirts's Avatar
CustomShirts CustomShirts is offline
Color: White 2-tone
Rep:172
CustomShirts has a spectacular aura aboutCustomShirts has a spectacular aura about
Hello,
There was a thread about this issue previously... something to do with the Gas Tank.
Take a look at the thread here:
http://www.ramforumz.com/showthread.php?t=50957
Hope this helps!!
Tim
Old 05-20-2010, 06:59 PM
Rep:44
Default Thanks Tim... I have the 32Gal tank so maybe thats
Originally Posted by CustomShirts View Post
Hello,
Hope this helps!!
Tim
it. Not really an issue but I wanted to make sure I didn't have a band loose or clutchpack issue in the trans.
The dealer "full tank at delivery" is probably the first and last time I'll ever have the truck more than 1/2 full lol. I'm a little under 3/4 tank right now and thats apparently where its most noticible.
Old 05-20-2010, 07:45 PM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PX8 Black
Rep:2471
Post
I have the 98 liter tank and do not have this issue. From the other thread it has something to do with the 121 liter tank.
Old 05-20-2010, 08:44 PM
Rep:44
Default Yep, its the 3/4 full tidal wave action lol.
Surely these things are baffled inside. Guess I could put some cell foam in it if it gets worse.
Old 05-20-2010, 10:30 PM
0007 0007 is offline
Vehicle: 2008 ram
Color: Bright blue
0007 is on a distinguished road
I mentioned this on another thread but it sounds like Tundra's have the exact same thing and it comes from the driveshaft
Sounds like Lash in the slipjoint maybe?, some of the tundra guys say that repacking the slip joint with grease helps
They both have Spicer drive shafts I believe
Old 05-21-2010, 09:42 AM
RansRAM's Avatar
Addicted to the Z
Color: PX8 Black
Rep:2471
Post
You should take it to the dealer as they may have a fix for this issue. It really should be a warranty issue since there is no way there should be bangs or bumping sounds when you bring your RAM to a stop.
Old 05-21-2010, 09:45 AM
Rep:1890
No the tanks aren't baffled inside. Due to the design of the pump/pickup/level float assembly, there is no need to baffle the tank.
Old 05-22-2010, 09:50 AM
Barnyard's Avatar
Barnyard Barnyard is offline
Vehicle: 2011 Ram 1500
Rep:209
I unfortunately have the smaller tank and I notice a slight bump with it 3/4's full as well. Sorry to blow your theory.
I hope this is a gas tank issue and not a drive train issue. I can't see why you'd only notice it with 3/4 of a tank if it was a drive shaft problem.
