2010 Hemi going to the track tonight! - Page 3 - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Drag Racing Discussion
Old 06-01-2010, 05:19 PM
CL8N CL8N is offline
Vehicle: 2010 RAM Crew Cab
Trim Level: Sport/Hemi
Color: Stone White
Rep:18
CL8N is on a distinguished road
This was in completely stock trim with about half a tank of gas. Stock tire pressure and everything. Just running the canned tuned. Guess it wasn't too bad.
2010 Hemi Crew-Cab Sport
1967 Camaro RS/SS
Old 09-06-2010, 02:46 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
..next time out drop your stock tire pressure to about 23-25 lbs...
Old 09-06-2010, 03:01 PM
MotorCityRam's Avatar
MotorCityRam MotorCityRam is offline
Vehicle: 2010 Ram QC 4x2
Color: Inferno Red
Rep:23
MotorCityRam is on a distinguished road
Dropping street radial tire pressure that much probably isn't going to gain you much. You just want to make sure you've got a flat contact patch and that's the pressure you should be running all the time anyway. Stock radial isn't going to have much sidewall flex.
You'll get better gains in the 60 by learning to pedal it out of the hole if you're getting a lot of spin. I've scored 1.9 60's on a 275/60/15 street radial w/ a 5spd and 4.56 gears in a car that would easily melt the tires through two gears.
Now....a drag radial is a different story...
Sean M
2010 Quad Cap Sport 4x2 / Inferno Red / HEMI / 3.92s / leather / Truxedo Truxsport tonneau
Old 09-06-2010, 04:21 PM
chefred112's Avatar
Rep:656
hmm..droppin my pressure on stock tires made a difference in my 60 fts (the first few times I went to the track...went from low 15's to high 14's doin that..
Old 09-06-2010, 07:34 PM
Color: Inferno Red
Rep:23
Just depends on what you were running to begin with. I'm always big on keeping the contact patch flat (check on dusty conditions, etc) so it may be why I never saw gains.
Sean M
Old 09-07-2010, 03:43 PM
UnLiMiTeD UnLiMiTeD is offline
Vehicle: 2010 Ram 1500
Trim Level: SLT Crew Cab 4x4
Color: Deep Water Blue Pearl
Rep:0
UnLiMiTeD is an unknown quantity at this point
i beleive a 3.55 crew cab would be a mid 15 second truck, one of those proffesional review magazines tested a crew cab and it ran a 15.6 stock
Old 09-07-2010, 04:53 PM
autobred's Avatar
autobred autobred is offline
Vehicle: sold* 10' R/T... 13' R/T
Trim Level: R/T
Rep:142
autobred will become famous soon enoughautobred will become famous soon enough
I need to try that, thanks...
at what rpms are you launching your truck?
Old 09-07-2010, 05:23 PM
chefred112's Avatar
Rep:656
I don't stall up at launch as tq management will try and pull power...but, with that said (and because i have a tq verter), sometimes i stall to around 2k right as the lights start comin down. It's been awhile so i have to remember what I use to do ...I'm goin this sunday so already I'm gettin butterflies..
Old 09-07-2010, 06:03 PM
autobred's Avatar
Trim Level: R/T
Rep:142
SUNDAY!! race DAY!! good luck bro..
come to think of it when I finally cracked the 13s, I was only revving at about 1500 rpms and walked it out and had a 1.996 60'.. guess Ill play with tire pressure next time to launch it a little harder..I see you did some head work and read somewhere you raised your rev limit. On gen 4 motors do you think I can raise the rev limit a bit? via diablo, motor is stock..I believe its shifting stock at 5600 rpms
by the way in the performance gen 4 threads a new member is asking about doing a power setup arrington head/cam swap..maybe you can help a brother out..Im curious too
Old 09-07-2010, 08:47 PM
Color: Inferno Red
Rep:23
hp peak is supposed to be 5600. If that's the case, shift point should be about 6100-6200. High side of that range for the 1-2 I'd wager and maybe closer to 6k for the 2-3.
Sean M
