replacing water pump - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 05-21-2010, 11:32 PM
Scorn440 Scorn440 is offline
Vehicle: 1998 dodge ram
Scorn440 is on a distinguished road
Default replacing water pump
I have taken off and put back on this water pump 7 times I replaced it because my old pumps pully was loose but now i cant get it to stop leaking the last time i got it where it was barley leaking at all but today when i got home from work it was spraying out of all sides of the water pump I don't know if i am doing anything wrong or if the pump is bad or what the old pump never leaked just shredded my belt i attached some pictures of what i am sealing my pump to there is some corrosion but it is not even leaking in there and i don't even know what i would do to fix that. any help would be appreciated
Old 05-22-2010, 08:20 AM
Resident Technician
Rep:1915
The mating surfaces need to be clean and smooth when you install the gasket and pump. There's no way what you've posted will seal.
Old 05-22-2010, 11:48 PM
I used a putty knife to scrape the most of it off and finished it off with a heavy duty green kitchen scrubby it is as clean as i can posably get it. "I did this after the pictures" I Got a new pump so it is clean but do i put the sealant on both sides of the gasket or just the water pump side?
Old 05-22-2010, 11:58 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Both sides....but don't get carried away with it. A single small continuous bead and let the installation squash the sealant into position. When done, you should see a small amount of sealant squeeze out all the way around.
Emphasis on -
Make sure it's clean, with no bumps from previous sealant/gasket
Make sure it's dry, even the slightest moisture reduces your chances of success
Make sure the sealant is continuous....no breaks. Where it starts/ends, let it overlap slightly. And apply as a bead; don't 'paint' it on.
Finally, too much sealant can get into the cooling system and raise havoc, so don't be over zealous.
Good luck!
brad
Interested in one of my mods?
Old 05-23-2010, 12:02 AM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
Old 05-23-2010, 12:18 AM
RansRAM's Avatar
RansRAM RansRAM is offline
Addicted to the Z
Color: PXR Black
Rep:2477
Thumbs up
Originally Posted by hemiv8dodgeram1500 View Post
YouTube to the rescue again !!! Having that as your home page can also be very helpful, that video actually made sense. How to change you waterpump in 30 seconds flat. If only life were that simple.
sales@revelperformance.com
Old 05-23-2010, 01:39 AM
Vehicle: Jeep GC WK
Rep:964
LMAO
Old 05-23-2010, 09:59 PM
ok i got it all together and let it run for about 15 min no leaks thanks for all the help
Old 05-24-2010, 12:58 PM
Resident Technician
Rep:1915
I don't use any type of RTV sealant. I use Mopar or Permatex spray on gasket sealer according to the directions and I never have a problem. You can't overdo it with this stuff.
Old 05-24-2010, 04:37 PM
well i drove into town today got home and it was poring water
