Old 05-22-2010, 07:19 AM
LittleKintnerBoy LittleKintnerBoy is offline
Vehicle: 2010 Dodge Ram 2500 Crew
Color: Brown
LittleKintnerBoy is on a distinguished road
Default Winch Questions for 2500
Ok, first thing first....Warn or Smittybilt for a winch with onboard compressor? I know they are both relatively the same on paper, but has anyone heard anything useful from the field? Second, is there any type of removable option like a front mount receiver for the 2010 Ram 2500? Looking at the specs, it looks like the line pull of the winch and the weight of the truck is too much for a front receiver. I'd like to remove it in the winter when I'm not going to use it much so it doesn't get wrecked by ice. Any info would be great...Thanks in advance
Old 05-25-2010, 05:30 PM
DodgeRamHD's Avatar
DodgeRamHD DodgeRamHD is offline
Vehicle: 2003 Dodge Ram 1500
Color: Goldish
Rep:14
DodgeRamHD is on a distinguished road
Im not sure about smittybilt but i know warn is a good winch, warn is whats on the dodge power wagons. Im not sure if you can just mount a hitch on the front but i know they come on a lot of full replacement bumpers so i would think that could be a option and it should be plenty strong enough and very easy to take on and off
Old 05-29-2010, 07:13 PM
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
just bumping it up
Old 06-03-2010, 12:29 AM
ttontis's Avatar
ttontis ttontis is offline
Trim Level: TRX Crew
ttontis is on a distinguished road
On my 2010 2500 there is a spot to mount the winch bracket to the frame and the grill insert can be removed. It would be the same set up as the power wagon, no bumper mods need to be made. Warn has the bracket that bolts right up.
Old 06-09-2010, 11:42 AM
WV2010powerwagon's Avatar
WV2010powerwagon WV2010powerwagon is offline
WV2010powerwagon is on a distinguished road
I run the warn powerplant on my Jeep. I installed a 2.5gl hotgog tank in the rear to be able to run air tools. The winch has a very strong constant pull but is slow (as long as you are not trying to enter a rockcrawling event who cares what the line speed is) and the commpresser has worked well. The only problem I have had is if it sits in the weather for too long it does not like to switch from winch to compresser but that is not really a problem since it is the same motor for both.
Old 06-26-2010, 10:47 PM
J Heavy J Heavy is offline
Vehicle: 2010 RAM 2500 4X4
Rep:21
J Heavy is on a distinguished road
What kind of line pull are you looking at? 12k or more I'm guessing?
