Old 05-23-2010, 10:07 AM
hpc3 hpc3 is offline
Vehicle: 2010 Ram 1500 Laramie Crew 4x4
Color: Inferno on Slate
Rep:44
hpc3 is on a distinguished road
Send a message via AIM to hpc3
Default On the front lower A arms: why are the drivers side and
passenger side alignment cams/bolts mounted 180 deg from each other side to side ie on the passenger side the bolts are mounted with the cams up(lower bolt axis) and on the drivers side they are inverted 180deg with cams down(bolt axis up). Is this to allow for driver weight?
Know Chrysler has done this in the past, drivers side always sits a little higher than passenger at rest, unloaded.
2010 Ram Laramie Crew 4x4, Inferno(mono) on Slate, All options, including BigSloshiTank
Old 05-23-2010, 10:14 AM
Rep:1909
That's just the way they wound up when the alignment was performed. The cams have nothing to do with ride height adjustment.
