Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Towing
Towing 3rd Gen Dodge Ram Towing Questions
Old 05-23-2010, 01:18 PM
460hpmach1 460hpmach1 is offline
Vehicle: 2007 dodge ram
Color: dark grey
460hpmach1 is on a distinguished road
Default don't know what you call this for towing
ok i'm new to the truck world. and i'm needing to know what this part is call and where the best place to look for one at, i got told you can buy em from uhaul. but i have the normal bumper with hitch, but i was wanting the one that goes underneath the rear bumper that is call (i think) class 3 reciver hitch. i think that is what its called. so i need to know the proper name and where the best place to find one, i'm planning on pulling my car on a flat bed trailer or enclosed and was needing to know what that item is so i can buy it. thanks
ASh
Old 05-23-2010, 01:21 PM
"receiver hitch" is correct. They mount to the truck frame in the rear. You can get them online, at your local truck accessory story and places like your UHaul stores.
To tow something that obscures your truck's rear lights, you'll need lights on your trailer and a wiring harness with connector to plug in the trailer wiring to your truck's lighting.
It's all pretty much plug and play these days.
Old 05-23-2010, 01:26 PM
Some things to consider when towing:
1. Your hitch class needs to be able to tow the load and handle the tongue weight.
2. Never tow more than your rated capacity. Your truck has a GVWR (Gross Vehicle Weight Rating) which is the combined weight of your loaded truck (truck, passengers, fuel, cargo) + the weight of your trailer + the weight of what's in or on your trailer.
3. Heavier loads require trailer brakes and a controller in your truck to make those brakes work in conjunction with your truck brakes.
4. Read up on different classes of receiver hitches. Determine the tongue weight of your load and overall weight of the loaded trailer. Weigh your truck, loaded. Then do the math.
5. Many trucks will be rated at a higher GVWR when pulling a 5th wheel or gooseneck trailer vs. a tow behind attached to a receiver hitch.
Just some things to consider and get all confused about. If you need help with all this, holler.
Color: dark grey
i think this is the right part i'm looking for they don't cost that much
http://www.suspensionconnection.com/...500-hitch.html
now with mine being the 5.7L and having the tow/haul button would that mean it already has the set up for the lights on it?
ASh
Old 05-23-2010, 01:28 PM
Look at your back bumper and a connector there for trailer lights.
Yes, that is a class III receiver hitch for your truck. Make sure that your trailer tongue weight and overall weight doesn't exceed the rating of a class III hitch.
hemiv8dodgeram1500's Avatar
Vehicle: Jeep GC WK
Rep:964
ASh
look on or under the bumper, it may need to be wired up since you dont have the towing package
Old 05-23-2010, 01:31 PM
Color: dark grey
this is what they said bout the class 3
Tow up to 5,000 lbs with this Quality S Class 3 Dodge Ram 1500 trailer hitch. Custom made to fit the Ram, this hitch a has 2 inch square receiver-style opening to accept various ball mount heights. This trailer hitch includes all required mounting hardware. Simple "no drill" design makes installation quick and easy. All Dodge Ram trailer hitches are powder coated for lasting durability.
the car weight is bout 3400lbs
Old 05-23-2010, 01:33 PM
Color: dark grey
well i will have to have the wife check for me cuz i'm in iraq and hard to go look right now,
ASh
thanks a bunch guys i may go with a class 4 just to be on the safe side
Old 05-23-2010, 01:34 PM
Vehicle: Jeep GC WK
Rep:964
ASh
its not only the hitch you have to worry about for towing capacity
Old 05-23-2010, 01:35 PM
Just because the hitch can handle up to 5,000 pounds it doesn't mean your truck can (GVWR).
You gotta understand how the whole towing a load thing works or you'll burn up your truck, the brakes, break the trans, or worse yet, end upside down off the side of the road. I've seen it happen.
