Old 05-23-2010, 07:14 PM
AtkinsoT AtkinsoT is offline
Vehicle: 2008 Dodge Ram
AtkinsoT is on a distinguished road
Default High Pitch Noise around 1500-2000 RPM
Hello,
Im new to this thread but I have a problem with my 2008 4.7L Ram I've been trying to figure out for a while now. I installed an aftermarket (Bully) short ram intake and ever since I have a loud high pitch noise around 1500-2000 RPM, which I wouldn't mind but it's constant when I'm driving on the highway. I thought it was originally the intake, but took it off completely and tried driving with straight air into the throttle and it was still there. Any suggestions?
Thanks
Tommy
Old 05-23-2010, 10:49 PM
Rep:1625
Welcome to the forum! Glad to have you here! Sorry, I don't have an answer for you, but I'll bump it up to the top
Old 05-24-2010, 12:56 PM
Rep:1885
What kind of noise? Whistling, whining, squealing?
Old 05-24-2010, 04:49 PM
It's a high pitch whistling noise. I can tell it's from air getting into or around somewhere to cause it. I initially thought the intake was making it, but I took the intake off and it was still there. And if I keep my foot just right on the throttle, it's constant around those certain RPM's.
Old 05-24-2010, 04:50 PM
Rep:1885
Have you checked for vacuum leaks?
Old 05-24-2010, 06:23 PM
No I haven't. I'll probably check that out and hope it'll be a quick fix. Thank you.
Old 05-24-2010, 06:28 PM
drp6982's Avatar
drp6982 drp6982 is offline
Vehicle: 2011 3500 SLT Diesel Dually
Trim Level: 3500 SLT
Rep:185
drp6982 has a spectacular aura aboutdrp6982 has a spectacular aura about
its usually the most obvious thing thats the cause. I would say if it literally started after the CAI install, then thats the problem. Have you swapped back to stock to see if it still has the problem ?
usually the install of an aftermarket cai will have some kind of whistle that was not there when stock.
My Mopar Stable: 07 SRT8 Charger 426 Stroker with Direct Port Nitrous (1/4 9.70@138.88mph)'
2011 Dodge Durango Crew 5.7L Hemi / Custom Katskinz
2012 Chrylser SRT8 300 optioned Out
2011 Ram 3500 SLT Big Horn Dually
Old 05-26-2010, 12:07 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
I have a K&N in mine, makes the same noise your describing....i can hear it but my dad can't...so its not a vacuum leak, i would say if you want to rule it out being the CAI then put your stock back on a see if it still there!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 05-26-2010, 12:15 AM
Rep:1885
Originally Posted by AtkinsoT View Post
Hello,
Thanks
Tommy
Wake up guys!
Old 05-26-2010, 01:58 AM
Ruffian11's Avatar
Rep:140
Yes remerson i noticed that too! Not a good idea in the first place!!!! and thats why i mentioned to install the stock intake before thinking it wasn't the CAI
