Old 05-23-2010, 07:33 PM
borderbandit4094 borderbandit4094 is offline
borderbandit4094 is on a distinguished road
Default Need help with new stereo install
I am trying to install a new aftermarket h/u in my 2008 Ram 1500 Quad Cab and have run into a problem that I can't seem to fix. The truck has a single CD player and no upgraded factory sound system (Boston).
The h/u is a Pyle DVD touchscreen unit (I know, I know - Pyle; I won it in a contest raffle). I installed my amps, subs, components and rewired everything with new wiring. I bought the basic aftermarket adapter from Autozone and plugged it into the original truck harness and wired it up to the h/u harness. Tried to power it up and I got nothing. I rechecked the wiring, all fine and even had the harness exchanged at the store and I still cant get the h/u to power up. I would plug the old stereo in and it powered up just fine.
I took the h/u over to the store that I picked it up at. They had one on display and I had them plug it up and test it. Well of course it worked there. The tech even checked the wiring harness that came with the h/u and it still worked. The guy offered to check it out, but couldn't fit me in till sometime next week.
I have installed quite a few car stereos before and have never run into a problem where the stereo just wouldn't power on. I am hoping someone else has run into this before or I might have to just swear off installing stereos forever.
Old 05-23-2010, 09:30 PM
Did you get the Pac Audio harness adapter?
The main harness and CAN BUS system in these trucks are tough to work with in a lot of areas. Pac Audio seems to have the right stuff to make aftermarket audio work with these trucks.
Old 05-23-2010, 09:58 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
Actually the factory turn-on wire carries such a low amount of power that most aftermarket units can't even recognize it. You might have to run a new turn on wire from the fuse box to the aftermarket unit.
Old 05-23-2010, 10:00 PM
oooh...I learn something every day!!!
So it may not be the harness but just more power?
Old 05-23-2010, 10:02 PM
2007Ram1500's Avatar
2007Ram1500 2007Ram1500 is offline
Vehicle: 2007 Dodge Ram 1500 4.7
Color: Grey
Rep:63
2007Ram1500 will become famous soon enough
yeah ive had the same problem with my JVC head unit now im just waiting on a new harness to get my 12's and new head unit put in!
Old 05-25-2010, 10:51 PM
dodgeman70592's Avatar
Vehicle: 2008 Dodge Ram
Trim Level: Custom
Rep:1648
Originally Posted by chithead View Post
actually the factory turn-on wire carries such a low amount of power that most aftermarket units can't even recognize it. You might have to run a new turn on wire from the fuse box to the aftermarket unit.
this...............
Old 05-25-2010, 10:52 PM
Man, I'll have to remember that when I re-do my audio...
