Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 05-24-2010, 05:30 PM
robmaed robmaed is offline
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
robmaed is on a distinguished road
Default Reverse lights not working
I have an 84 Dodge Ram d150 318 v8 manual transmission. The reverse lights do not work, but every other light does(brake, tail lights, head lights, turn signals, parking lights and high beams) any common problems and possible solutions? thanks
-rob
Old 05-24-2010, 05:32 PM
Rep:1885
Backup light switch, bad bulb ground, blown fuse, blown bulbs or a wiring problem. I'd start by checking the switch if the fuse is good.
Old 10-27-2010, 12:55 AM
Ram50Man's Avatar
Ram50Man Ram50Man is offline
Vehicle: 1989 Dodge Ram 50
Trim Level: Standard
Color: Primered Black
Rep:71
Ram50Man will become famous soon enough
Hey guys, im gonna piggy back off this instead of sarting a whole new thread since i have a similar problem. I have a 89 Ram 50, my fuse for my reverse lights keeps blowing! all my other lights work, with the exception of my dome lamp. Any ideas, i dont know electrical systems at all other than the main fuse box. Thanks.
'89 Dodge Ram 50: 2.0L, 5 SPD Manual, 2 WD.
Old 10-27-2010, 12:59 AM
RootBeer RootBeer is offline
Vehicle: 2014 Ram 1500
Color: RootBeer
Rep:1287
You need to put a meter to the wiring for that circuit. There's a short someplace.
Brian:
Old 10-27-2010, 07:41 AM
Ram50Man's Avatar
Rep:71
Dang, thats what i was hoping it wasnt... lol
**EDIT: I put my test light to the fuse box, the fuse is getting power, but it blows the fuse as soon as i put the tranny in reverse. it calls for a 15 fuse i tried a 10, 15, 20, and 30, blew them all. I checked the bulbs, and the bulbs appear to still be good. I checked the wires under the truck, they look good as far as i can tell, nothing unplugged, or torn. There is however a mysterious green wire that runs from the left tail light to the right one. Its definetly not factory as it is outside the factory spiral wrap. The other lights work fine, parking, brake, and blinkers.
