Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 1ST Generation Dodge Ram 1993 & Older Dodge Ram Trucks > Electrical
Electrical 1st Gen Dodge Ram Electrical Problems and Questions.
Old 05-24-2010, 07:47 PM
sjolley sjolley is offline
Engine: 1981-1987 318ci (5.2L) LA V8 140hp
sjolley is on a distinguished road
Default power door locks
hi,
i have a 1985 d150 pick up. the locks say electric lock on the top of the pull knob. the passenger door can be locked and unlocked by hand, the driver door cannot be locked at all. the passenger door lock doesn't seem to be working "electrically" I am wondering the components involved and what may need replacing. I am seeing a relay available at the auto part stores.
Old 07-06-2010, 10:17 PM
pavementends's Avatar
pavementends pavementends is offline
Vehicle: 2007 Ram 2500 5.9 Cummins 4x4
Color: White/Camo Accent
pavementends is on a distinguished road
Sorry Brother i dont have your answer but i drive a 07 and have the same problem. It worked when new and slowly one by onequit working cept for the drivers door. Any answers out there for both of us?? THANKS!! Whoops just realized this is the forum for Gen1 Rams. Sorry i reposted correctly
Dyin is easy for men like you and me, its livin that's hard. -Josey Wales-
Old 10-19-2010, 10:34 AM
jmorton84's Avatar
jmorton84 jmorton84 is offline
Vehicle: 2006 Dodge Ram 1500 4d
jmorton84 is on a distinguished road
When you say you cant lock it at all, you mean even pushing down on the pull knob? if so, it sounds like your door lock motor is seized up. you should be able to just remove the door panel and reach in and disconnect the rod that links the motor to the lock and be able to lock your door, it will just be manually. and if you happen to find somewhere to replace the lock motor for cheap, let me know. I was told it was a dealer item and they want like 140 for it here.
Old 03-21-2011, 11:46 PM
Thunder38843 Thunder38843 is offline
Vehicle: 1987 Dodge Ram 4x4
Trim Level: No Idea
Color: 2 tone - Brown and Tan
Rep:13
Thunder38843 is on a distinguished road
Same problem here. Jmorton is correct... My passenger door will lock manually but it has the rod disconnected as J stated. The driver door will not lock at all and the rod is still connected (But, it won't be as soon as it gets day light) Hope this helps ya! I can live without power door locks.
Old 03-22-2011, 12:10 AM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
It looks like you've gotten some good guidance here. Hope you drop by more often. I wish you a big hello and a warm Carolina welcome. I hope you enjoy the best RAM ForumZ.
Old 06-02-2011, 05:01 PM
want to drive want to drive is offline
Vehicle: 1990 Dodge ram D150
Trim Level: LE
Color: gray/ blue
Engine: 1989-1992 360ci (5.9L) LA V8 190hp
want to drive is on a distinguished road
I have the same problem on my pap's 1990 150. I believe the motor is good put the linkage is frozen. it twitches when you hit the switch but you can lock it by hand.
If you are looking under my truck, you are to close to my truck
