Old 05-25-2010, 06:49 AM
Dodgem's Avatar
Dodgem Dodgem is offline
Vehicle: 05 4.7L 1500 2WD
Trim Level: Quadcab
Dodgem is on a distinguished road
Send a message via Yahoo to Dodgem
Default 3.55 vs 4.10
I don't do alot of towing but I travel alot long and short trips. 365/70/17 with 3.55 in diff, 75 mph, 17-ish mpg, is not a 4x4.
Would I get better mpg with replacing to 4.10 or just leave it the way it is?
Does one of the the two make the engine work less harder?
k&n drop in, airraid intake tube, nerf bars, bosch plat single grd, fiberglass cover, 90k
Old 05-25-2010, 06:53 AM
Resident Technician
Rep:1915
If you want overall economy, stick with the 3.55. If you want more grunt while towing, change to the 4.10.
Old 05-25-2010, 07:01 AM
Dodgem's Avatar
Trim Level: Quadcab
Straight to the point, thats all I need to know, thanks Rem I want to be just like you when I grow up
Old 05-25-2010, 08:27 AM
Resident Technician
Rep:1915
You really should set your goals a bit higher...
