Old 06-21-2010, 05:37 PM
09 TRX AGGIE 09 TRX AGGIE is offline
Vehicle: 2013 1500 Black Express 4x4
Rep:130
09 TRX AGGIE will become famous soon enough09 TRX AGGIE will become famous soon enough
if i am reading your dyno sheet right, you actually lost power at the higher rpm range?! but gained a lot at lower rpm's.
Old 06-21-2010, 05:59 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
No, I know the pictures are small, but if you look closely, the first dyno run shows a lower starting RPM, so its a bit misleading. If you check the HP to RPM ratio, he gained pretty much throughout.
2015 Camaro 2SS/RS/1LE
Old 06-22-2010, 06:08 PM
SPEEDFREAK's Avatar
SPEEDFREAK SPEEDFREAK is offline
Vehicle: 2010 RAM R/T
Trim Level: 450HP & 450TQ
Color: SPEED WHITE
Rep:180
SPEEDFREAK has a spectacular aura aboutSPEEDFREAK has a spectacular aura about
Default new dyno sheet
352hp and 360tq gains all over the place
k&N CAI, 3 1/2" 90 on CAI at TB, 85mm BBK TB,denso sp,180stat,syn oileng & rear gr,Catchcan, Addco sway bars f&r
1 3/4"amer rac hders high flowcats, 2 1/2" H pipe dul 2 1/2" piping, Diablo CT, Bilstin, Mcdrop 2/4,1deg cam 295/45-20bfgkdw,efan,13.4gtech
Old 07-08-2010, 03:10 PM
SPEEDFREAK's Avatar
Color: SPEED WHITE
Rep:180
Default hp and tq will be going up on the hemi !
iam getting the exhaust redone true dulls and an x pipe. ill post the new dyno #.
