Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 05-26-2010, 02:26 PM
apcdrewie420 apcdrewie420 is offline
apcdrewie420 is on a distinguished road
Default standard tranny problems
I got a 2000 half ton 5.2 4wd 5 speed and puttin new clutch in and cant get the tranny to line up with the motor. Is there any tricks that make this easier spent two hours last night and nuttin. also what kind of fluid does the tranny and T-case take
Old 05-26-2010, 02:35 PM
Rep:1625
I see this is your first first, welcome to the forum! Glad to have you here! Sorry, I'm no help on this one, but hang in there, another member may be able to help you out. Don't forget to make your official welcome in the "Newbie Checkin" section
Old 05-26-2010, 02:36 PM
Resident Technician
Rep:1909
Did the input shaft line up and go easily into the clutch disc?
Old 05-26-2010, 03:44 PM
Rep:2705
I used to drop & reinstall standard sticks quite often
after several tedious installs, i cut a input shaft off of a transmission that was laying around
now anyone can buy a set of plastic pieces that do the same thing, most auto parts stores have them
what it does is line up fly wheel, clutch, pressure plate grooves, making it almost childs play, when you try to stab the transmission
