Old 05-26-2010, 07:26 PM
clatla's Avatar
clatla clatla is offline
Color: Snow White
Rep:31
clatla is on a distinguished road
Default Stereo Question
Ok I have a 2010 Laramie with the radio w/Uconnect. It does not have the camera or GPS. Last week I ran to the store and had no sound. I tried turning it off and on volume up and down. Nothing. After getting back into the truck to come home it worked fine. Today I pulled my truck out to wash it and when I went to put it back into the gararge it said radio off in the dash. I looked at the radio and it was off. I had not turned it off. I tried to turn it back on and nothing. Turned the key off for a couple of seconds and back on and it turned on. My question is anyone else having issues? Is there any TSB's? Thanks in advance for any help. Just want to have some amo before I call the dealer.
Old 05-26-2010, 07:37 PM
Rep:1890
No TSB's. Looks like you may be shooting blanks.
Old 05-28-2010, 06:43 PM
blue09's Avatar
blue09 blue09 is offline
Vehicle: 2012 Ram 1500cc
Rep:19
blue09 is on a distinguished road
in response to your problem, i have had this happen with my 09 many times. All of the sudden you start the truck, radio is off and will do nothing but eject or load a disk but not turn on. I keep a 10mm wrench in my truck to disconnect the battery and reconnect it after and everything works fine....untill the next time it happens. I have it happen every few months. I have the nav and gps. By the way, the dealer knows nothing about this problem.
Old 05-29-2010, 11:09 AM
clatla's Avatar
Color: Snow White
Rep:31
Thanks for the response. I will have it in soon and get it at least on my history.
Old 05-29-2010, 02:42 PM
SHARKINDUBLIN SHARKINDUBLIN is offline
SHARKINDUBLIN is on a distinguished road
Default WOW
The 10mm did the job. Thanks..
Old 05-29-2010, 03:30 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
The 'Ol 10mm repair!!!
Since 2004, I have had 4 times where a truck has done....well....strange things. Like, won't crank the engine over....or it starts, but the gas pedal does nothing.....or the headlight switch turned on the wipers...not the headlights...
Each time, I called the dealership and asked for suggestions, and each time they recommended towing to them so they could diagnose the problem. However, each time, I was not in a position, time or location, that allowed for that scenario, so I did the 10mm fix. Up side, it worked each time, and the problem never came back. Down side, the 10mm fix clears all codes, so there is no way to ever find out what was causing the issue....unless it came back!
SO - I finally went out and bought a code reader so that I could at least get a code before doing the fix....and have never needed the code reader!
Well....at least it's there if I ever need it....wonder if the code reader has batteries....should check....just in case!
brad
Interested in one of my mods?
Old 04-09-2011, 11:20 PM
vtx dodge vtx dodge is offline
vtx dodge is on a distinguished road
Default ren radio turning off alot
I have been having problems with my REN Radio turning off when I am driving or at a dead stop.It just well freezes up and wont let me turn the volume up or use the touch screen and then dies but it well come back on for a few minutes and do it again.Whats going on anyone have a answer because it is just about to cause me to buy something new.
Old 04-17-2011, 10:32 PM
brad12kx's Avatar
Rep:2581
Is your truck still under warranty?
brad
Old 04-24-2011, 09:11 PM
RickMopar RickMopar is offline
Rep:33
RickMopar is on a distinguished road
i had the same problem with my 10, no gps or back up cam, just u connect. Radio would turn off, no sound all kinds of wierd stuff. Took it to the dealer, they said they did know about the problem there is an update that they will load into your radio, it will work fine once they are done.
hope this helps.
Rick.Mopar@Gmail.com
