Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > Dodge Ram Detailing and General Maintenance Forum > Fuel System
Fuel System All Fuel Discussions. MPG - Mileage - Fuel System Maintenance including Air Filter Replacement.
Old 05-28-2010, 03:02 PM
sesrgulledge sesrgulledge is offline
sesrgulledge is on a distinguished road
Question ouestion for a mopar dummy
I just replaced my old motor with another less old motor that gave me more than a few surprises but the major problem now is the scanner is pulling up a inj not firing in the right sequence code, stupid me cant remember the code at the moment,but this is a new one for me and the thing is all was running well till I put water in the motor and the timing cover must of had a stress fracture in it because as soon as the motor built up pressure the timing cover cracked and broke the timing chain, I removed the old chain from my other motor that had been replaced not so long ago and it hasn't idled right since and has very little power!
please any help?
Old 06-04-2010, 09:27 AM
Resident Technician
Rep:1915
Sounds like the timing is a tooth off.
Old 06-05-2010, 11:39 AM
Are you getting water into the motor ? Head gasket ? Hydra lock ? Are you sure you got a good motor ? Takes alot to break a timing chain .
