Old 05-28-2010, 10:50 PM
Carvermitch's Avatar
Carvermitch Carvermitch is offline
Vehicle: 2002 Dodge Ram 1500 quad
Color: Garnet Red metelic
Rep:12
Carvermitch is on a distinguished road
Default C Code 00 00 on 2002 Ram 1500 4.7
The engine light keeps comming on and the C Code says 00 00.
I disconected the battery and it goes away for a day or so the comes on again. All functions are normal , gauges are all normal and she runs perfect. How can I get rid of this light pleease. Thanks
Paul
Old 05-28-2010, 11:54 PM
Rep:1625
I see this is your first post, welcome to the forum! Sorry I'm no help, I'll leave this one to the professionals on here
Old 05-29-2010, 12:10 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
C0000 = Vehicle Speed Information Circuit Malfunction.
Never come across this before. Don't even know where to start looking. Does the speedo work ?
brad
Interested in one of my mods?
Old 05-29-2010, 12:11 AM
brad12kx's Avatar
Rep:2581
Oh and, Welcome you to the forum,
This forum is full of great looking trucks, and packed with great mod ideas and there are loads of knowledgeable and experienced people here.
AND - We all like pix! Got any to share ?
Enjoy the Z!
brad
Old 05-29-2010, 07:54 AM
Rep:12
Hi Thanks - It cant be anything serious then cause everything works fine.
Thanks for the help and welcome.
Old 05-29-2010, 06:29 PM
Rep:12
Default Ram stereo problems
The stereo/CD player in my 2002 Ram goes for a while then cuts out. If I turn it off then on again is goes for a few minutes and does the same thing. This is the same for the radio and CD player. It does not loose power as the clock and that keep going . It sometimes goes for 20 - 30 minutes other times on 2 - 3 minutes.
It always starts again as soon as I turn it off then straight back on again.
Any suggestions please
Thanks
Paul
Old 05-29-2010, 06:38 PM
brad12kx's Avatar
Rep:2581
Even though the clock is still working, check the power connections/fuses. The radio/CD part has more than 1 power wire. There is a constant power, and that is what the clock uses. There is also switched power. It is the switched power circuit that appears to be failing. Could be as simple as a loose fuse, or as complicated as an intermittent in the radio unit. Have you noticed whether it cuts in/out when you drive over bumps?
brad
Old 07-17-2010, 11:27 AM
Rep:12
I purchased another stereo the same from ebay - plugged it in and hey she works fine so must have been the stereo. Only cost me $10 for second hand stereo identical original unit out of another ram so I guess I did ok. Many thanks for all the help.
Old 07-17-2010, 02:22 PM
brad12kx's Avatar
Rep:2581
That is a great deal especially when it fixes a problem. So now that you have a functioning radio, just have to find the source of the C0000 code, and your set!
brad
Old 07-18-2010, 06:20 PM
Rep:12
Thats about the size of it other than the trailer wiring
