Old 05-29-2010, 06:53 PM
Scotty1500 Scotty1500 is offline
Vehicle: 2000 dodge ram 1500
Color: red
Scotty1500 is on a distinguished road
Default water leak , help please????
so i have a 2000 ram 1500. 5.9L standard cab, when it rains heavy the passenger side like gets wet under the speaker, there only is about and 1in of water the there that i vacumed out, does anyone else have this problem and a solution to it??? sorry no pics
Old 05-29-2010, 10:16 PM
Check your door and windshield seals.
Old 05-30-2010, 10:40 AM
denis13285's Avatar
denis13285 denis13285 is offline
Trim Level: lamarie
Color: forest green
denis13285 is on a distinguished road
2 ways to check, first the door have someone inside the truck while you spray water near the door jam not directly. and if it does not leak still spray, onto the door jam if still nothing check the windshield. if your able to get ahold of an air compressor take some soap and water it doesnt have to me a tramendous amount of soap in the water, spray some on the outside of the windshield under the molding start on top and do half the windshield at a time and take the air line and blow from the inside of the truck up where u put ur soap n water. have some1 outside and cheak for bubbles, if it bubles up very slightly in a particular area spray some more soap on it you will see itll bubble up a lot more and you have found your leak. I work at a body shop and we've had our fare share of water leaks they seem impossible but theres many more ways to check. if you cant find it anywhere around the windshield or door, theres more places your can check.
