Old 05-30-2010, 06:13 PM
dodgepower89
Default A/C Intermittenly blowing.
Hey everybody this is my first post! I regret to make my first post asking mechanical questions but i'm in a bind! So here is my problem any help will be greatly appreciated! Ok I have a 2004 Dodge Ram 1500 QCSB 4x4 with the 4.7. My ac was working fine and then no matter what speed it was on it would just stop blowing. Then in a few minutes it would work again. Then stop again and now it won;t blow at all. My compressor clicks on and runs fine. I pulled the blower motor and tested it and it works fine. I changed the blower motor resistor and it still won;t work. The fuses and relays all check out. So i'm thinking that it is either the control switch in the cab or it is in the ignition where the blower draws power from. What do yall think?
Old 05-30-2010, 06:28 PM
Rep:1884
This should help you out. The switch is possible but pretty unlikely.
Old 05-30-2010, 07:39 PM
dodgepower89
Well i'm not getting any voltage at the resistor or the blower motor. I'm thinkin it's in the ignition switch?
