Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Powertrain > 4.7L PowerTech V8 Specific Topics
Old 05-30-2010, 11:23 PM
lt173 lt173 is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Trim Level: SLT Plus
lt173 is on a distinguished road
Default Miss-fire code
I'm just posting this again in the more specific area.........sorry newbie. Thanks.
Hi everyone looks like a great site. Have a question right off the hop. I'm having an issue with my 05 Ram 1500. It's the 4.7.
Basically I'm getting a check engine light. Diagnostics said miss-fire cylinder eight. Changed the plugs out and code cleared. Came back a week later same diagnostic info. Changed the ignition coil yesterday, cleared the code went for a cruise all was fine. Today the light is back on and the diagnostic is still saying miss-fire 8th cylinder. Would appreciate any input, thanks.
Old 06-22-2010, 11:53 AM
fixitfirstime's Avatar
fixitfirstime fixitfirstime is offline
fixitfirstime is on a distinguished road
Has your truck gotten low on coolant lately?
Old 06-24-2010, 12:40 AM
RamCountry's Avatar
RamCountry RamCountry is offline
Vehicle: 2006 Dodge Ram
Trim Level: Reg. Cab Laramie 4x4
Color: Atlantic Blue Pearlcoat
Rep:64
RamCountry will become famous soon enough
i agree with fixit you probably need to do a compression test on that cylinder just to make sure your not dealing with anything major so you can rule out it being a head gasket hope you find out whats wrong!
Old 06-24-2010, 02:28 AM
Actually I got the system flushed, noticed a gurgling sound on the passenger side of the cab. Read how these motors are bad for filling and have a tendency to air lock. Was pretty low in the overflow container and had read some other members post about starting it up taking the cap off waiting for the thermostat to kick in and adding anti-freeze as well as squeezing the upper rad hose. Doing this I was able to get a jug and a quarter in. Since then the overflow jug has maintained the same level. Pretty concerned though cause today the code has changed from a P0308 to a P0300 (non-specific cylinder miss-fire) but more importantly noticing a fair bit of white exhaust. For about 3 blocks then it disappears not sure if the cat is keeping it from going longer, or I'm leaking into a cylinder, or gallery when she sits and burning it off. What's weird is it does not smell like anti-freeze at all but my instincts think it's a head gasket. I'm the only owner, oil change every 5-6 K. 170,000 k on it. Guess )(%^ happens.
Old 08-27-2010, 04:22 PM
DodgieDan DodgieDan is offline
Vehicle: 2003 Dodge Ram 1500 Quad Cab
DodgieDan is on a distinguished road
Almost totally guarentee your head gasket is shot and most likely because of the overheating your head is warped. Best way to check is have your local shop pressurize the cooling system and pull the plug on the effected cylinder and check for leaking. Your white cloud of exhaust is pretty much a guarentee that you need to change head gaskets and the head as well. Best thing to do is both sides when you get it done.
