Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Body & Interior
Old 05-31-2010, 11:59 PM
09 CrewCab's Avatar
09 CrewCab 09 CrewCab is offline
Vehicle: 2013 Dodge 1500 Crew Cab Sport
Trim Level: SPORT
Rep:23
09 CrewCab is on a distinguished road
Default Water Leak
I have looked under the TSBs and did not see anything on this...
It has rained for a few days here in Montana and I notciced a large puddle of water in the small cubby area under the rear passenger seat. The water was running down from above the seat belt area. Top rear passenger corner of the cab. Went to dealer on Friday and have a appointment for Tuesday morning. would it be too much to ask for the replacement of the carpeting in that area since it already has a smell to it. Anyone else have this problem? I thought it may be coming form the SAT antenna.
Old 06-01-2010, 12:07 AM
PorkChop's Avatar
PorkChop PorkChop is offline
Vehicle: 2009 ram 1500
Trim Level: sport
Color: brillian black
Rep:75
PorkChop will become famous soon enough
in my opinion jumping to replacement may be a bit much. get a full detail and if the funk small remains, then start replacement talks with them
DODGE the father RAM the daughter!
Old 06-01-2010, 02:15 AM
kutect's Avatar
kutect kutect is offline
Vehicle: 2009 Dodoge Ram
Trim Level: Crew 4x4 Big Horn
Rep:24
kutect is on a distinguished road
I had that problem, last month, it's coming from the back break light area. The dealer told me the seal in between the lights and the body parts was SPLIT in half, so they replace the seal and tested it. It's fine now, although i haven't had a rain storm since the fix, it's under warranty, so no worries. You might have to leave the truck there for one night, if it's the same issue i have, if not it they might need a few days to replace the whole back window. Hope that helps!!
Mopar: 4" lift kit/cold air intake/dual exhaust/tublar step bar/35" BFG KM2 tires/RBP 95R wheels
Old 06-01-2010, 07:30 AM
vided vided is offline
Vehicle: 2010 ram quadcab
Trim Level: slt,big horn,bucket
Rep:22
vided is on a distinguished road
i had the exact puddle under that pesky passenger seat.
dealer said it was the third brake lite seal.
so far so good.
Old 06-01-2010, 09:48 AM
Subydude09's Avatar
Subydude09 Subydude09 is offline
Vehicle: 2009 Dodge Ram 1500
Trim Level: Sport 4x4 Crew
Rep:50
Subydude09 will become famous soon enough
Wow, I've heard alot of 09's have leakgae problems. Lots of ppl are havin issues around the front passenger pillar. Now around the rear lights... You guys are making me worry...
*Tow Hooks *LineX *Truxedo Bed Cover *SS Step Bars *HID's *Flowmaster 40 *35% Tint *Nightshades
Old 06-01-2010, 11:37 AM
MightyBlueRam's Avatar
MightyBlueRam MightyBlueRam is offline
Vehicle: 2014 Ram 1500 EcoDiezl Laramie
Trim Level: Laramie 4x2
Color: Blue Streak Pearl Coat
Rep:432
MightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really niceMightyBlueRam is just really nice
There was a TSB on my truck dealing with resealing the 3rd brake light. I never noticed a leak with my truck but they resealed it anyways. Every car and truck has a problem here or there. Don't start getting discouraged.
Old 06-03-2010, 11:36 PM
09 CrewCab's Avatar
Trim Level: SPORT
Rep:23
Default Got my truck back
Well got my truck back the next day. They put in a seal around third brake light and did a RRT on the front passenger side tire, some kind of seal replaced.
My question is if the third brake light seal is a permanent? I like to change my bulbs out. I try different styles (LED, Blue xenon) until I find one i like. I do not want to keep returning to the dealer to get a new seal around the brake light. Those bulbs do burn out. If that was the fix, I dont think that was the right way to go.
Old 06-08-2010, 06:02 PM
Rogue's Avatar
Rogue Rogue is offline
Vehicle: 2009 Ram 1500 Crew Cab 4x4
Trim Level: TRX, 25T pkg w 5.7 L
Rep:22
Rogue is on a distinguished road
Send a message via ICQ to Rogue
I just took my truck to the dealer for a oli/filter/lube/rotate and they said that issue was a rapid response item. There were a few of them that they took care of, a axle seal and a sticker under the hood I believe.
Old 06-08-2010, 10:58 PM
Rep:432
From what I remember when they resealed my third brake light, the receipt said something about silicone. That to me doesn't sound like anything permanent since any bulbs will eventually burn out like you said.
Old 06-08-2010, 11:03 PM
Rep:1885
Correct. It will have to be resealed each time it's taken out.
