tonneaucovered.com
Old 06-01-2010, 11:10 AM
wbrown1 wbrown1 is offline
wbrown1 is on a distinguished road
Default Covermaster Topper Tail Light (CHMSL)
I recently purchases a Covermaster Topper for a 2004 1500. I tried wiring the 3rd brake light and have it all hooked up correctly to the CHMSL wire and ground. I tested a different light and it worked fine, but the brake light won't turn on. I connected a multimeter to the brake light and no reading showed. All the wiring looks good in and out of the light. I would be shocked if the LED bulb set is burned out but I don't know any other reason why it won't turn on. Any suggestions?? Or what is the best way to change out a topper brake light??
Thanks for any help.
Old 06-01-2010, 12:12 PM
Resident Technician
Rep:1911
Did you check continunity?
Old 06-01-2010, 12:25 PM
Rep:1625
I see the is your first post, welcome to the forum! Sorry I'm no help on this one. Don't forget to stop by the "Newbie Checkin" section for your official welcome
Old 06-01-2010, 12:29 PM
I did test continuity, and nothing showed, double check my meter and a different bulb, incandescent, and things worked fine. I was just reading that most LED bulbs take at least 1 volt to force the circuit into continuity. Might have to double check my meter.
chmsl, light, tail, topper, wiring
