Old 06-01-2010, 05:36 PM
MrsBuck's Avatar
MrsBuck MrsBuck is offline
Vehicle: 2007 Dodge Ram 1500
Color: Inferno Red
Rep:32
MrsBuck is on a distinguished road
Default I need advice bout removing running boards, Please.
I am trying to figure out how to remove the running boards on my 2007 Ram. The bolts are bolted to the chaise and there is no access to nuts. The bolts just spin. I am a bit nervous to cut them, but I will if i have no other solution. I want to replace them with nerf bars, later on. Dunno what to do. Anyone else have this problem? Or a suggestion how to do this.
Old 06-01-2010, 08:07 PM
bones64's Avatar
bones64 bones64 is offline
Trim Level: slt/sport (bones)
Rep:659
Are you running boards factory ones or aftermarket..........I had the factory ones and they werent hard.Let me know. Can you get a pic or two to help out?
Old 06-01-2010, 08:31 PM
MrsBuck's Avatar
Color: Inferno Red
Rep:32
yep there factory...thanks for the help
Old 06-01-2010, 09:09 PM
bones64's Avatar
Rep:659
I have a 03 on the ones i had were factory. There should be two nuts side by side and then two more below in the same fashion. Take one nut off complete and lossin the other. They are on like a E shape bolt with threads on the ends.You have to pin the bolt a bit to manouver it out.Hope this helps.
