Old 06-02-2010, 10:31 AM
hunTer06's Avatar
hunTer06 hunTer06 is offline
Vehicle: 2011 Dodge Ram
Trim Level: Outdoorsman
Rep:60
hunTer06 is on a distinguished road
Send a message via MSN to hunTer06
Default transmission cooler?
I have a 1998 Ram 1500, 5.2 318. Does this truck come stock with a tranny cooler? I am still in Afghanistan, and for the life of me I cant remember if there is one on my truck.
They have these on ebay, and im going to buy one if my truck doesnt have it.
http://cgi.ebay.com/ebaymotors/4-Sea...Q5fAccessories
Old 06-03-2010, 03:18 AM
hunTer06's Avatar
Rep:60
ttt...,,,,,
Old 06-03-2010, 01:30 PM
strang3majik's Avatar
strang3majik strang3majik is offline
Vehicle: 1996 Dodge Ram Indy Pace Truck
Trim Level: Indy Pace Truck
Color: Blue w/ white stripes
Rep:210
strang3majik has a spectacular aura aboutstrang3majik has a spectacular aura aboutstrang3majik has a spectacular aura about
it depends what packages your truck was ordered with and all.
But, if you have a little cooler on the front of the a/c condesor able to be seen through the grille, then yes you do. As a matter a fact, mine runs through the radiator and its own dedicated cooler. Not sure if the rad part is stock, but, I have seen many of them with the dedicated cooler.
98 Jeep Grand Cherokee 5.9 Limited / 96 Dodge Ram Indy Pace Truck / 87 Dodge Charger GLHS / 85 Dodge Omni GLH
Old 06-05-2010, 06:36 PM
Paul89's Avatar
Paul89 Paul89 is offline
Vehicle: 1998 Dodge Ram 1500
Rep:20
Paul89 is on a distinguished road
Strang3majik Is correct about the small tranny cooler that is between the ac condesor and radiator. And going thru the radiator. I'm getting ready to go to my third transmission in my truck and I'm installing a larger external cooler. Transmission shop recommend a larger cooler due to the nature of these trannys. Also if you haven't removed the check valve that is by the radiator, do it. They have been a problem also.
Old 06-05-2010, 07:05 PM
Yeah, it does depend on how the truck was equipped for towing and gears when it was built. If you have the stock Class III receiver hitch and wiring, I suspect you do have one.
Old 06-05-2010, 07:26 PM
Rep:2657
It would be hard to see your truck in Ohio from Afganistan, but, have someone pop your hood & take a picture or 2 of the whole radiator area & then they could email it to you & you could post it in here
Old 06-06-2010, 12:54 PM
hunTer06's Avatar
Rep:60
Thanks for the reply's. I will have someone check it out. Sounds like I should buy a bigger one even if there is a stock one.
PAUL89
thanks for the tip on the check valve. I will do that as well.
Old 06-06-2010, 06:08 PM
Thats a good price . I purchased one from Dodge several years ago and spent over $125.00
Old 06-07-2010, 11:38 AM
Rep:210
Just turn the overdrive off when you tow or haul heavy stuff, and your tranny will be fine. And change the fluid and filter at regular intervals as well.
Thats with the trans cooler though. Those are very good to have.
Old 06-07-2010, 11:43 AM
RamTech RamTech is online now
Rep:1885
You might want to consider adding a transmission temp gauge as well. That should be part of any instrumentation/towing package IMNSHO.
