Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 4.7 Liter V8
MOPAR DECALS
Old 06-03-2010, 10:39 PM
jayhkr's Avatar
jayhkr jayhkr is offline
Vehicle: 2006 Dodge Ram SLT 4x4
Color: Atlantic Pearl Blue Metallic
Rep:75
jayhkr will become famous soon enough
Send a message via ICQ to jayhkr
Just a thought, as this is what I do with bigger diameter things that won't come off nicely. Take a belt and wrap it around the pipe you want to come off and use it as a giant "wrench". It's kind of like that rubber pickle jar opener only bigger. Hope you find a solution soon. HOWEVER, if you get a chance in take a short video of your open headers I would LOVE to hear how they sound. Good luck!
Old 06-03-2010, 10:52 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Like they've been saying above...Fire up the smoke wrench....or just drive it as is....with the MIL light on!
brad
Interested in one of my mods?
Old 06-03-2010, 11:40 PM
Rep:3337
I had a hell of a time removing mine as well as the U-bolt they used had actually folded the downstream pipe into the upstream. I had to get my sawzall out and cut into the downstream pipe to loosen the tension then it pulled out no problem.
Old 06-03-2010, 11:53 PM
afkst6's Avatar
afkst6 afkst6 is offline
Vehicle: 2007 Ram 1500 QC 4.7L Flex 4X4
Color: Inferno Red
Rep:26
afkst6 is on a distinguished road
So they sent me a 5.9L Diesel exhaust. Not to shabby looking so I thought. I'm only 70 minutes from Summit in Ohio. I got there get the parts I need to make it work and I'm just having trouble... it should work... but maybe I'm just too tired. I'm thinking about calling it quits... Anyone know of a place near pittsburgh that has an aftermarket exhaust?
07 Ram 1500 QC 4.7L Flex 4x4 Mods: RanchoQuicklifts(F)|Rancho9000XL(B)|DIY CAI|SC|Corsa Exhaust
Old 06-04-2010, 10:11 AM
afkst6's Avatar
Color: Inferno Red
Rep:26
Update... I called it quits. Put an extension of Pipe I had on going just past the cab. I'm sending the other POS back and just dealing with it when I get back from travel.
Old 06-04-2010, 11:05 AM
Torq89 Torq89 is offline
Vehicle: 2005 Ram 2500
Color: Grey
Rep:87
Torq89 will become famous soon enough
I was in your position a couple months ago. Trust me I spent about an hour trying to "shake" the OEM exhaust off. Before I tied a chain to it and ripped it off I grabbed the sawzall and the problem was gone!
Old 06-19-2010, 08:51 PM
benbob benbob is offline
Vehicle: 2004 Dodge Ram QC Long box 2wd
Color: Silver paint code ps2
benbob is on a distinguished road
If you are trying to save the old exhaust, I would heat the pipe up cherry red with a torch and wiggle it off. If you don't care what happens to the old exhaust, it really doesn't matter so much if you cut it whether it be with torch, sawzall, air hammer, or cut off tool, like MADDOG said. But even then, I think it is easier to just heat it up and pull it off.
~Ben
Old 06-19-2010, 09:13 PM
got hemi's Avatar
got hemi got hemi is offline
Color: Platnum Metalic / Silver
Rep:40
got hemi is on a distinguished road
i just did mine today, i have an '04 so its got a healthy amount of rust and years behind it. use the sawzall and make sure you leave enough room for the new piping to go on just dont hack it off anywhere. grab a good supply of wd-40 and lube it up and beat the clamp right off of the old pipe top to bottom or side to side, then repeat for the old left over section of pipe. it took me 20 min to get the old exhaust off by doing this. good luck!!
Mr. Grimm
Mod list here :
http://www.ramforumz.com/album.php?albumid=130
Old 06-19-2010, 09:30 PM
Rep:2875
WOW!!!
I would never use WD-40 on anything that is going to be near any flame, that stuff is highly flammable, if you don't believe me, roll up a piece of paper TIGHTLY, clear the area of anything that will burn, now take a sprayer with WD-40 in it, light the paper double check the area & sparingly spray the burning paper with WD-40
I have used this method for getting rodents out of automobile box frames
I'll take an air or electric grinder with a cutting blade on it & do a nice controlled cut
Old 06-19-2010, 10:11 PM
got hemi's Avatar
Rep:40
yeah i know its flamable, i made sure everything was high and dry before i put the new exhaust on, and if your working with a completely cold pipe I.E. not run for like 8-9 hours you wont spontaneously combust while your doing it. but common sense would tell you to clean it up and make sure not to spray it into the old pipe work
Mr. Grimm
Mod list here :
