Fuel pump in 96 Ram 1500 question - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-03-2010, 03:11 PM
markj's Avatar
markj markj is offline
Vehicle: Ram 1500 1996 Magnum 5.9L
Color: Metallic Black
markj is on a distinguished road
Default Fuel pump in 96 Ram 1500 question
As most would know the Ram 1500 has the filter built into the "Fuel pump module" basically a single unit that has the fuel filter, pump, gauge sensor and fuel check valve all together that is housed inside the actual fuel tank.
There is no external filter outside the fuel tank.
Question can it be changed so that the fuel pump and filter is housed outside the fuel tank ???
How difficult would this be, and has anyone else done this?
I know the easy option is to simply buy a new Fuel pump module and stick it in, 30 minute job, but wouldnt it be nice to have the fuel pump, filter etc outside bolted onto the chassis for easy access and maintanance instead of having to release the fuel tank every time.
All the best.
Mark.
Old 06-03-2010, 03:18 PM
Resident Technician
Rep:1915
I know it can be done but for the cost and labor I don't personally think it's worth it unless you're running it in a high performance application.
Old 06-03-2010, 04:29 PM
Besides Mark you don't have to change the pump but maybe once in the life of the vehicle .
Old 06-03-2010, 04:35 PM
Resident Technician
Rep:1915
Assuming you don't use cheap aftermarket parts.
