Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Diablo Predator Questions & Info!
Old 06-03-2010, 05:18 PM
ram2487's Avatar
ram2487 ram2487 is offline
Vehicle: 2011 Dodge Ram 2500 Mega Cab
Rep:37
ram2487 is on a distinguished road
Default where to change.
i was wondering where i would change the thermostat settings in the predator menu. i've been looking and can't find anything. i'd like to install the thermostat in the next few days or so, but don't want to do it without the tune, or is it not required to adjust it in the tune?
2011 2500 6.7l Mega Cab Laramie 4X4
Old 01-01-2011, 06:40 PM
old hot rod's Avatar
old hot rod old hot rod is offline
Vehicle: 2010 Dodge Ram 1500 4x4
Rep:386
old hot rod is just really niceold hot rod is just really niceold hot rod is just really niceold hot rod is just really nice
Send a message via Yahoo to old hot rod
not sure on an 07 but on a 09,10 you go under "cooling fan off, on" and adjust the points where the fan turns on and off, hope this helps
Hell Bent Steel Leveling kit, K & N filter, Tinted Windows,
Mufflex DOD18M, Mopar Intergrated Trailer Brake,
DiabloSport Predator (U7137) 180 Thermostat, WeatherTech Vent Visors
DiabloSport Catch Can (C-1040)
Old 01-01-2011, 07:15 PM
MADDOG MADDOG is offline
Rep:22
You don't adjust the thermostat setting you change the cooling fan settings.
Old 01-02-2011, 04:17 PM
09ChallengerDad 09ChallengerDad is offline
Vehicle: 2011 RAM 1500
Trim Level: Laramie 4X4 Quad Cab
09ChallengerDad is on a distinguished road
Correct. All you have to do is go to "Modify Tune" and lower the fan settings. Of course, if you don't have a cooler than stock thermostat installed, you'll just be turning the fans on more often and draining your electrical system without much (if any) improvement in operating temperature.
