Belt noise - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > 5.2L V8 Specific Topics
Old 06-03-2010, 10:35 PM
eddie7644 eddie7644 is offline
eddie7644 is on a distinguished road
Default Belt noise
Ok I have a 97 5.2L and I have changed the belt 3 times and it still squels, no matter what it is very annoying and can not figure it out. Any help would be great.
Old 06-03-2010, 10:38 PM
Make sure your grooves in your pulleys are clean and not worn out . Could also be a bad tensioner .
Old 06-03-2010, 11:01 PM
brad12kx's Avatar
brad12kx brad12kx is offline
Vehicle: 2010 Ram 1500 QC
Rep:2581
Are you sure it's the belt?
Disclaimer/Caution/Warning - The following information should only be used by someone with their head screwed on tight. The dangers 'SHOULD' be self apparent. If not, do not even consider trying this !! Leave the troubleshooting to a professional. - End Disclaimer/Caution/Warning
An old trick.....not sure if it works on the new serpentine belts....pour a 'small' amount of water on the belt while it's running. If the noise stops, it's belt noise...if not...it's something else.
brad
Interested in one of my mods?
Old 06-03-2010, 11:34 PM
Rep:3347
Lol, Brad, that's some real CYA right there! If the belt's still good, then I'd lean towards a bad pulley somewhere or the tensioner. The tensioner is the most likely culprit and can be changed out pretty easily.
Old 06-04-2010, 01:26 AM
brad12kx's Avatar
Rep:2581
Yes! I fully consulted with my legal adviser prior to.
brad
Old 06-04-2010, 08:21 AM
Resident Technician
Rep:1915
Silicone spray also works well for this. A spray bottle of water is also useful for hunting down vacuum leaks.
Old 06-04-2010, 04:32 PM
i replaced the tensioner twice also. I dont know what it is. It sounds weird but I heard that I may need to go get it reflashed to get rid of it.
Old 06-04-2010, 04:39 PM
Rep:4264
I don't know about getting it reflashed, but I chased this forever in my Jeep, until we got a mechanics stethoscope which helped find the bad pulley as we could hear it. Good luck!
Old 06-04-2010, 04:41 PM
Resident Technician
Rep:1915
Who told you that? I'd like to know how they think a software update will cure belt noise. The tensioner isn't the only rotating component with bearings. Check all the pulleys for roughness, looseness, and excessive wear. Alternator bearings are notorious for squealing when they get old. A stethascope can aid you in pinpointing the noise.
Old 06-24-2010, 04:12 PM
NoShineMM NoShineMM is offline
Vehicle: 2015 Dodge Ram
Trim Level: Larmie/Crew
Color: Deep Cherry Red
NoShineMM is on a distinguished road
it squeals ALL the time? i know this is stupid but make sure it is routed right. i had this problem and it would make a nice squel for me because it was routed wrong.
