Old 07-09-2013, 07:22 AM
pick pick is offline
Vehicle: 1996 dodge ram 2500HD
Trim Level: SLT Laramie
Color: Aqua and clear White
pick is on a distinguished road
Originally Posted by rdsabin View Post
Personally I would just put steel on and be done with it.
Yes, and how about giving the new lines a double coat of POR 15. That's amazing stuff and I have used it to battle rust on several other of my old project cars in past years. One quart will go a long ways and you'd have enough to spot touch other rust problem areas.
Old 07-16-2014, 03:55 AM
melliam melliam is offline
Vehicle: 2001 Dodge Ram 2500 4x4 V10
Color: Blue
melliam is on a distinguished road
Originally Posted by Alfisto Steve View Post
Well, I joined the rusty brake line club yeserday when the pedal went to the floor. Lucky no cross traffic at stop sign.
I dropped gas tank today and removed the long 10' plus line. I think is is a 52009911AB will have to see if dealer has one Monday.
Thanks Steve for the pics! $78 for a hose flare kit with tube cutter, 5' of brake line with union nuts, and assorted new bolts to replace crap that rusted, and voila, done. Of course, it took this sap a whole day.
Couldn't get gas tank strap to come off, but taking the two nuts off one side allowed the tank to drop and slide over enough to access the brake line (also loosened two clamps on rubber hoses - vent and fillup hose). Used Irwin clamps to push tank over. I had the exact same carnage as Steve. The chassis brake line running to back axle had blown beside tank. The plastic clamps holding brake line and fuel line had helped corrode line. Guess winter salt gets caught up there. I was worried back metal bracket which holds transition from metal to rubber line was hooped, as mine looked worse than yours, but was able to unscrew metal line. When pulling line out back, the line broke in another spot, so this swap out was long overdue.
Was a bear with tank being half full. Getting tank straps back up nearly killed me...tight fit. Again, clamps and crowbar helped.
Hopefully, line is good for another 13 yrs. Just have to see about lines running to front, as they look as bad as the line I just fixed. Nasty feeling pushing brake to floor and Big Blue not stopping.
Oh yeah, used this helpful pictorial to make my flares. http://www.stu-offroad.com/suspensio...etool/ft-1.htm
(2 pages)
Old 01-17-2015, 09:15 PM
t-johnson19881 t-johnson19881 is offline
Vehicle: 2001 dodge ram
Trim Level: sport
Color: forest green pearl
t-johnson19881 is on a distinguished road
So that thing that the main brake line changes into that high pressure line is that change over really needed cud mine is toast would I be alright continuing with my normal brake line down to my rearend then put in a T and then run left and right??
Old 01-19-2015, 12:51 PM
prattman prattman is offline
Vehicle: 2012 Dodge Ram 1500 QC 4x4
Rep:23
prattman is on a distinguished road
I ordered an EGR Stainless Steel Pre-bent brake line kit from Circle Track Supply for my old 1998 Dodge Cummins 2500 4x4. I had a shop do the swap. I don't remember what I paid for the install as I had other work done at the same time. The line that usually rusts out is the brake line that runs down the drivers frame rail next to the fuel tank. Here's the link for the kit: http://www.circletracksupply.com/pre...s-2wd-4wd.html . For $349.95 I think it's worth it. Do it once and be done with it. -Glen
