Old 06-06-2010, 02:46 AM
RocKstArDoDge RocKstArDoDge is offline
Vehicle: 1998 dodge ram
RocKstArDoDge is on a distinguished road
Default Dodge ram stuck in drive !!!!!
So i drive down the highway to go see a car im interested in probably a 45 min drive. As i pull in i go to put truck in park and the lever slides over as if theres nothing connected to it, just kind of freely moving. I put it in park and when i take my foot of brake the truck goes backwards. Now i put it in drive and it moves formwad but now thats all it will do. No matter what gear it says im in the truck will just drive. I was able to drive it all the way home but now its stuck in my driveway since i cant turn it on because its in drive. NO cel and no leaking fluids. WTF could it be
Old 06-06-2010, 03:08 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Since I'm not familiar with that model year, I can only suggest basic ideas that are general to most vehicles with mechanical shift mechanisms and a shift lever on the column.
Check the shift rod that attaches to the steering column and goes down and connects to the transmission. Sounds like it came out of one end or the other. Possibly the clip that holds it on...fell out/off.
Please ensure you have the truck properly blocked before going under it. With the symptom you described, it could easily roll, and while DIY can deal with it quicker and likely less costly, it's not worth getting hurt over.
brad
Interested in one of my mods?
Old 06-06-2010, 12:01 PM
It might be the linkage has popped off or is loose, out of adjustment.
Old 06-06-2010, 02:43 PM
If i get under truck will i be able to see the linkage ??
Old 06-06-2010, 03:06 PM
Found the problem. Theres a plate that has two bolts that bolt to the fram on the linkage. The two bolts snapped off so that the plate wasnt attached to nayhting. Gonna have the plate welded bacnk on
Old 06-06-2010, 05:24 PM
Can you extract the broken bolts ? I would rather make that attempt first . I don't like to weld things like this unless I absolutely have to .
Old 06-06-2010, 11:32 PM
brad12kx's Avatar
Rep:2581
This is really good advice!
Preserves serviceability, and doesn't apply any heat to the frame!
brad
