Old 06-06-2010, 01:40 PM
Jeegz Jeegz is offline
Vehicle: 2002 Dodge Ram 1500 Quad Cab
Color: Black & Chrome
Rep:52
Jeegz will become famous soon enough
Question Window switch issue
I have one issue with my windows switches. Sometimes they work and sometimes they dont. The master panel on the driver side door always works. But the other three work when they want too. Now i was wheeling once and pincched myself against a tree and pushed my door handle in a little bit. Is it possible that this has caused a short? Or maybe i have a bad ground? I have no idea where to start to figure this one out! Help please!
Old 06-06-2010, 01:57 PM
Or maybe the connect has been slightly re-arranged and not fully plugged in.
Old 06-06-2010, 08:18 PM
Rep:52
Ive checked that on the passenger front door. Unless having one partway clipped in can cause it. Ive never checked the door that hit the tree.
Old 06-06-2010, 08:20 PM
Yeah, if the connector is not fully seated, that would cause a circuit interruption.
Old 06-06-2010, 09:20 PM
Rep:52
i'll have to check that out this week and see if thats the issue.
Old 06-07-2010, 09:54 AM
Rep:1885
If the master switch always works but the other three doen't, the problem is likley to be the lockout in the master switch itself.
Old 06-07-2010, 12:34 PM
Delasangre's Avatar
Delasangre Delasangre is offline
Vehicle: 2001 Dodge Ram 1500 2x4 5.2
Color: blue
Rep:31
Delasangre is on a distinguished road
I had the same problem with my 2007 f150 which I recently replaced with my Ram. First time it was the drivers switch which was replaced under warrenty and I was told it was a known problem with Ford. 2
nd switch was on passenger side and Ford would not replace free becuase warrenty had gone out 1 month prior.
Old 06-12-2010, 08:48 AM
Excoastie's Avatar
Vehicle: 2014 VW Jetta GLI
Color: Metalic Black
Rep:1358
sounds like a loose connection... like Randy said.. probably on the drivers' master switch.
good luck and let us know what you found
Exco
Bill
Old 07-05-2010, 05:22 AM
tinniste 079 tinniste 079 is offline
Vehicle: 2005 dodge ram 1500
Color: charcoal grey
Rep:53
tinniste 079 will become famous soon enough
that sounds right i know if one is unpluged they wont work
Old 07-05-2010, 08:53 AM
Agreed , check the driver side switch .
