Biggest wheel and tires - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-06-2010, 11:28 PM
434STROKER 434STROKER is offline
434STROKER is on a distinguished road
Default Biggest wheel and tires
Hey guys, FNG here. I got a 2005 ram 1500 with a 5.7 in it. Does anyone here know how big I can go with a wheel and tire combo on stock suspension without running into rubbing issues. Thanks
Old 06-07-2010, 10:27 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
I'm running 295/70/17 Nitto Terra Grapplers right now and don't have any issues.
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 06-15-2010, 01:22 AM
Silver05Ram's Avatar
Silver05Ram Silver05Ram is offline
Vehicle: 2005 Dodge Ram
Rep:98
Silver05Ram will become famous soon enough
I've got a 2005 2wd Ram 1500 and I'm running Mickey Thompson 35x12.5x20s with no rubbing issues. No lift or level. So you'll fit them also.
35" Mickey Thompson ATZ's/stock 20's painted black. Tinted Tails. Dynomax Bullet Resonator. LED's inside cab. Debadged. 12k Hid's
Old 06-15-2010, 03:29 AM
jacob tamblin's Avatar
jacob tamblin jacob tamblin is offline
Vehicle: 1995 Dodge Ram
Trim Level: Laramie SLT
jacob tamblin is on a distinguished road
wouldn't it depend on whether or not his truck is 4x4 or not? what i mean is doesn't the 2x4 model sit lower than the 4x4?
Old 06-15-2010, 11:24 AM
Rep:98
Yeah the 2wds usually do sit a little lower, but if my 2WD can fit 35s his truck will also. 2wd or 4wd.
Old 06-18-2010, 01:20 AM
blacdog06 blacdog06 is offline
Vehicle: 2006 dodge ram 1500
Color: light kakhi metallic
blacdog06 is on a distinguished road
Default tires
i have a 2006 ram 1500 4x4 and i wanna up to at least a 265/70 17 but prefer 285/70 17. so what size wide wheel is widest on a stock truck u can go without rubbing? heard a 9 inch? isnt the stock wheels 8 inch wide??
Old 06-18-2010, 10:33 PM
Rep:98
What are you talking about? Your wheel isn't gonna rub, your tire will. The wheel size doesn't matter as long as it isn't too skinny or too wide for your tire. I have 12.5 inch wide tires and they don't rub.
Old 06-19-2010, 12:42 AM
yeah and apparently u dont know that if u run a wider wheel it will change your tire width and therefore can cause rubbing when sharp turning.
Old 06-19-2010, 12:50 AM
ScatPak07's Avatar
Rep:970
I do not think getting the biggest tires possible and stuffing them under teh wheel wells is the best idea. If you want to make it look really good go with a 33" tire and get a leveling kit. The level will cost you like $100 and it will look much better.
I do not want to say any ones truck looks bad or anything do not get me wrong. It is my personal preference to have some visible space between the truck and the tires.
I have a 07 4x4 with a 2.5" front and 1.5" rear lift. I am only running 33" tires and I have tons of room under the wheel wells. I can fit 35" tires and they will fit comfortably with room around them. I actually like the way the truck looks now even though they are only 33" tires.
Old 06-21-2010, 10:17 PM
Rep:98
Yeah I knew that, you said "wheel size." If you have 8, 9, or 10 inch wheels on a 12.5 inch tire it's gonna be all the same. A stock 20" on a 12.5 inch tire is gonna touch the suspension at full left lock. Of course a 10 inch wheel is gonna rub, why would you even ask that?
