Old 06-07-2010, 03:01 PM
got hemi's Avatar
got hemi got hemi is offline
Vehicle: 2004 Dodge Ram
Color: Platnum Metalic / Silver
Rep:40
got hemi is on a distinguished road
Default possibly a stoooooopid question
i know you cant use a level kit on a suspension lift, but can you use it with a body lift?, since none of the suspension geometry will change
Mr. Grimm
Mod list here :
http://www.ramforumz.com/album.php?albumid=130
Old 06-07-2010, 03:06 PM
Rep:1824
Uh, a level kit will change the steering geometry.
Old 06-07-2010, 03:24 PM
Yeah, geometry will change with the leveling kit but you can also lift the body if you choose to.
Old 06-07-2010, 05:52 PM
got hemi's Avatar
Rep:40
hmmmm i didnt think the level kit would change anything with the steering or suspension, you learn something new every day.
Mr. Grimm
Mod list here :
Old 06-08-2010, 09:03 PM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Ya the level kit pretty much lifts the front diff up...which in turn changes the angle of the cv-shafts and the lower control arms!! doing this with a body lift should not be a problem tho
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-08-2010, 09:12 PM
ScatPak07's Avatar
Rep:970
You can use a body lift with any sort of suspension lift. They are two totally different ways to lift the truck. Also you can use the leveling kits with other suspension lifts. If you have a spacer on the front strut you can keep it there if you are doing a suspension lift (unless that kit comes with one).You cannot use two spacers on top of eachother, that would just be bad haha.
If you do do a leveling kit you do need to get an alignment as well. It does change around the geometry of the truck.
Old 06-08-2010, 11:07 PM
got hemi's Avatar
Rep:40
i want to lift my truck but i dont know yet if i wanna go all out and go with suspension, so i figured a level kit and a body lift will do, and besides if i do decide to go with a suspension lift down the road ill get 9 inches of lift total.... 3" body and a 6" sus. lift, with that in mind you think id be able to snag 1 set of rims and just up the tire if i do go all out with sus. lift????? im looking at 22's with a 35-37 depending what i can cram under the truck after the 3" body w/ the level.
Mr. Grimm
Mod list here :
Old 06-15-2010, 03:58 AM
hemi05's Avatar
hemi05 hemi05 is offline
Rep:35
hemi05 is on a distinguished road
I know of a guy with a suspension lift and a 2.5" leveling kit. All they are is the torsion keys. It will change some but I wouldn't think it would be major. I have a suspension lift on mine and with everything installed, I don't see what a leveling kit would hurt.
Old 06-15-2010, 01:34 PM
djinn4 djinn4 is offline
Vehicle: 2010 dodge ram 1500
Trim Level: SLT Big Horn
Color: deep water blue
Rep:13
djinn4 is on a distinguished road
im not claiming to be any kind of expert but i thought i had read some place on here that you could stack leveling kits and suspension lifts.
Old 06-15-2010, 05:48 PM
Ruffian11's Avatar
Rep:140
I'm not sure how you would stack a leveling kit?? especially with the torsion bars! the reason for 3" level being the max you would want to go is the fron CV joints would be running at such a sever angle if you went anymore, thats why the 6" suspension kits have alot of drop brackets, and again im not sure how you could stack those to drop things more? it deffinitley doesn't seem safe!
