Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, Complaints, & Solutions - Maintenance & Re > 2ND Generation Dodge Ram – 1994 to 2001 Dodge Ram Trucks > Body & Interior
Old 06-07-2010, 06:47 PM
Zman Zman is offline
Vehicle: 1994 Dodge Ram 2500
Color: rust
Zman is on a distinguished road
Default Wheel lug question
I hope this is the right forum, I saw no others for 2nd gen rams wheels. I have a 94 2500HD with the 5.9 LDC. My wheels are all 8 lugs, everywhere I go to find new wheels don't have any for me since its 8 lugs and all they carry for that year is 5 lugs or so they tell me. Where can I get some nice aftermarket wheels for this beast?
Old 06-07-2010, 06:52 PM
ScatPak07's Avatar
Rep:970
Why not try tirerack.com they have lots of stuff! Just search for 8 lugs wheels, but you do need to find the bolt pattern. My truck has 5 lugs and they are a 5/5.5(137) bolt pattern (I think hahaha).
Do a search for all year trucks similar to yours and find that bolt pattern. It should be the same for most Ram 8 lugs
Old 06-07-2010, 07:21 PM
Rep:2664
1994-1999 1500 2WD/4WD Aluminum Wheels
•Lug Pattern - 5 on 5.5", 1/2" bolt
•Rim Size - 16x7.0"
•Offset - +13.97mm
•Backspace - 5"
•Max Tire Size -
•15x8.0 rims with 3.5" backspace will fit, but they stick out of the wheel wells.
1994-2002 Dodge Ram 2500/3500's have 6.5 on 8 bolt patterns.
some fords, chevys, & jeeps look like they also use the 8 lug 6.5 pattern
lug patterns for some other vehicles, as well as our RAMS
http://www.offroadunlimited.com/orus.../lug_chart.htm
Tire Rack & Discount tire either have them in stock, or can get them in a day or 2
check out their websites to choose the type that you want
Discount Tire (NCC-02)
8521 Concord Mills Blvd
Concord, NC 28027
(704) 979-0950
Old 06-14-2010, 10:54 PM
Color: rust
Gah! I am about to pull my hair out. No one has the 8 lug chromed wheels for the 2500's. All I can find are the steel wheels and I only need one chrome to replace the steel wheel on it.
EDIT:Found one on ebay for 100+shipping. It is 16x6.5 8 lug chromed like I need. I don't know the wheel width on mine now, did most people opt for the 8 lug steel wheels on the 2500's or what?
Old 08-21-2010, 11:23 AM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
mlrtym is on a distinguished road
i picked up a set of 06 factory takeoffs for mine. 17", polished aluminum, with center caps and michelin's - $900 delivered to the border, and each about 30# lighter than the steel wheels. There are several guys on ebay that have factory takeoffs available. be careful as all the 8-bolt wheels will fit the bolt pattern, but there is one (chev/dodge or ford) that will not fit the others. It is an issue with caliper size i think.
It is better to let one think you a fool, than to open your mouth and remove all doubt.
Old 11-01-2010, 09:09 PM
MaxPower1971's Avatar
MaxPower1971 MaxPower1971 is offline
Vehicle: 1993 250--1994 2500--2005 2500
MaxPower1971 is on a distinguished road
•Rim Size - 16x7.0"
•Offset - +13.97mm
•Backspace - 5"
•Max Tire Size -
Concord, NC 28027
(704) 979-0950
Careful with the GM rims....they won't fit over the hub if you have lockers in front, as a matter of fact they don't fit on the back hub either!! Had one as a spare only to find out it don't fit. Bolt pattern is the same, but not centers.
MaxPower
