Old 06-08-2010, 01:03 AM
dev1's Avatar
dev1 dev1 is offline
Vehicle: 2010 Dodge RAM R/T
Rep:42
dev1 is on a distinguished road
Default 2010 Ram Lowered, Passenger Wheel sticking out!
Hello I have been looking through all the forums, and have not seen this problem before.
I had my 2010 Ram R/T Lowered in our shop, using the Mcgaughy' s 2/4 Deluxe kit. the spindles seemed to push out both front tires past the body. this was fixed a little after the alignment.
But today I finally got my 22" wheels, and installed them. They are 285/45/22tires on the 9.5" wide rims with the factory back spacing, but now the drivers side front tire sticks out from the body by about 1/2", but and the passenger side sticks out 1 1/4", I thought they sent me one wrong wheel, but we measured and all the rims are the same.
so I am wondering if anybody has had this happen to them?
Old 06-08-2010, 08:06 AM
Rep:1885
Do you have the spec sheet from the alignment after you lowered your truck?
Old 06-08-2010, 09:10 AM
MS520's Avatar
MS520 MS520 is offline
Vehicle: 2004 Dodge Ram
Trim Level: Hemi
Rep:109
^ What he said.
Hope you got it aligned already.
Mike
'04 Ram
"Yea its got a hemi!"
Old 06-08-2010, 11:21 AM
Rep:1625
Welcome to the forum!
Old 06-08-2010, 12:35 PM
sowardcustoms's Avatar
sowardcustoms sowardcustoms is offline
Vehicle: 2013 Ram R/T
Trim Level: R/T
Color: Gray
Rep:145
sowardcustoms will become famous soon enoughsowardcustoms will become famous soon enough
Yes the front spindles do push them out mine did the same thing wished I would have went with springs instead of spindles as far as the difference in right and left sounds like one has more camber than the other....
Old 06-08-2010, 12:53 PM
Rep:1885
That's what I'm thinking but that much of a cross-camber difference should cause a pull to the right.
Old 06-08-2010, 09:56 PM
GregInAtl's Avatar
GregInAtl GregInAtl is offline
Vehicle: 2012 Ram 1500 QC
Color: Dk cherry red
Rep:130
GregInAtl will become famous soon enoughGregInAtl will become famous soon enough
Did you measure hweel width or back spacing. Lay both front wheels face down on a blanket. Lay a 2"x4" over the wheel and measure from mounting pad to edge of the 2x4"...
I bet they arent the same.
12 Ram express QC, belltech 963sp and McGaughys spindles, debadged,Polk audio, smoked lights, tint, bedcover, and lots more
06 Stratos 201 Pro XL 225 Yamaha
Old 06-10-2010, 01:42 AM
dev1's Avatar
Rep:42
Thanks for the responses.
So the Alignment was done right, and the tech had brought in both sides am much as he could. the actual distance sticking out on both sides, is 1" on the drivers side, and 1.5" on the passenger side.
I talked to our body, and trim guy, he said he has had to adjust the cab over on the frame for a few customers, i guess it only has to go over by 1/4". according to spec that's acceptable.
I have ordered 2 new front wheels, that have 3/4" more offset (+35) to bring the wheels in, this is most I could get, but at least it will be a little more flush to the body!
I will put up some pic ( as soon as I figure out how to)
Old 06-10-2010, 01:53 AM
dev1's Avatar
Rep:42
Ok so I might need to make these pictures smaller, but can see what i am upset about!
Old 06-10-2010, 03:12 PM
09 RT RAM's Avatar
09 RT RAM 09 RT RAM is offline
Rep:39
09 RT RAM is on a distinguished road
Talking
Dev1, there are numerous posts on this issue (McG drop spindles) in the various forums. I will have to take a pic on mine this evening.... but the tires stick out on all 4 past the body stock OEM!!! I am not happy with what I am hearing about the drop spindles....hence they sit in the box on the garage floor. I might go GroundForce. Not much choice with turn key suspension systems. The aftermarket is LAME. Where is Eibach and the rest of the aftermarket??? Thank you for the photos and trying to sort these issues out.
