Old 06-09-2010, 11:37 AM
sledmanwinder sledmanwinder is offline
Vehicle: 2006 dodge ram 3500 mega cab
Color: blue/ gray
Rep:12
sledmanwinder is on a distinguished road
Question whistle noise coming from under truck
I have a 2006 dodge ram mega cab 4x4 3500 I have a whistling noise coming from the under carriage I have replaced u joints tie rods front axle bushings replaced rotors brake pads greased everything I could think of that would cause this noise it does it around speeds of 30 to 60 then when I come to a complete stop it doesn’t do it .. any ideas guys . (Would axle bearings in the front axle cause the noise?) ( also would new wheels cause the noise i went front 17's to 22's im just wondering if the wheels might be whistling but i wouldnt think they would?) Its bugging me bad can’t figure it out for the life of me
ELK HUNTER
Old 06-09-2010, 12:02 PM
Rep:1845
Whistling noise is commonly associated with wind related issues. Either that or you have dwarves whistling while they work under your truck.
Old 06-09-2010, 12:05 PM
Color: blue/ gray
Rep:12
thanks randy
ELK HUNTER
Old 06-09-2010, 01:54 PM
CORUPTWJ's Avatar
CORUPTWJ CORUPTWJ is offline
Vehicle: 2009 Dodge Ram
Trim Level: St
Rep:37
CORUPTWJ is on a distinguished road
The rims are a possiblity of the whistling noise. Especially if you didn't have the problem until after you put the rims on. I know a friend of mine had a whisling noise that came from the hubcaps on his car. He just took them off and was fine since then. A good way to check would be to put the old rims back on (if you still have them) and see if you have the problem.
Old 06-09-2010, 02:59 PM
Rep:2616
You could maybe take some painters tape & use it to cover your rims to see if the whistle goes away, if that doesn't work, put the tape over any pipe ends that may be catching air.
i have heard strange sounds coming from ski racks & trucks that have any kind of rack, maybe something on your under carriage could be doing the same thing. The tape is cheap enough & won't leave the glue on your truck like duct tape would do
Old 06-09-2010, 03:06 PM
Rep:1845
That trick can also be used to eliminate or confirm wind noise caused by body gaps.
Old 06-15-2010, 01:28 AM
Incognito's Avatar
Incognito Incognito is offline
Vehicle: 2003 Dodge Ram 1500 Crew Cab
Trim Level: 5.7L Hemi 4x4
Color: Graphite Gray
Rep:72
Incognito will become famous soon enough
I had whistling noise coming from my '03 Ram 1500 Hemi when I drove at higher speeds and it was only due to the design of the side mirrors.
