Old 06-09-2010, 03:15 PM
MOPAR MULiSHA's Avatar
MOPAR MULiSHA MOPAR MULiSHA is offline
Vehicle: 2012 Dodge Ram 1500
Color: Sage Brush Pearlcoat
Rep:219
MOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura aboutMOPAR MULiSHA has a spectacular aura about
Default Latest Mod :-) Cheap and Easy the way I like em!
After taking off the roll bar monday to touch up some blemishes I started looking at my grille, then next thing I knew I was at Home Depot buying gutter guards lol I think you can figure out the rest from there. Here's a pic with it's 1st catch of the day included haha.
Oh and removed the front air dam.
2012 Sage Brush Pearlcoat Ram 1500 Big Horn Crew Cab Hemi 4x4 w/ Ram Box Storage System
Old 06-09-2010, 03:51 PM
Rep:1625
Looks really good, I like it
Old 06-09-2010, 03:55 PM
wermbang wermbang is offline
Trim Level: Sport- Off Road
Rep:1930
Gotta love the gutter guard insert!
Old 06-09-2010, 04:02 PM
Rep:219
yup! and using the cutting wheel attachment on my air compressor to cut just the bars out of the old grille insert then using the frame to hold everything together the gutter guards fit nice and flush.
Old 06-09-2010, 04:06 PM
texas05ram's Avatar
texas05ram texas05ram is offline
Vehicle: 2005 Dodge Ram 1500
Rep:20
texas05ram is on a distinguished road
How did you attach them to the grill insert frame?
Old 06-09-2010, 04:08 PM
chithead's Avatar
chithead chithead is offline
Trim Level: R/T Baby!!!
Rep:2078
That's nice! I still like the color matched grille. The mesh complements it very well!
Old 06-09-2010, 04:18 PM
Rep:219
Damn haha someone did this DIY on another forum but I did the same thing he did except not on a Dakota lol. check it out.
(getting pictues since link won't work)
Old 06-09-2010, 04:20 PM
Rep:219
Thanks, I'm loving it more and more also. I'm thinking next month I'll have my Line-X done :-) (bumpers & bedliner) then no more chrome :-D
Old 06-09-2010, 04:53 PM
Rep:219
Unsnapthe grille insert from the main shroud
Using a cutting wheel attachment for an air dremel (plastic isn't that tuff if you don't have one you can probably use a razorblade or hacksaw blade) cut the inner bars from the frame.
should have this when done (the space is for the Dakota's hood latch, on the 1500's it'll be a complete loop)
Next you'll need 4 gutter guard pieces ($1.49 at Home Depot) and lay the mesh accross the main shroud openings using a permanent marker, outline the opening on the outer parts so the mesh will overlap on the edges a little bit and trim with tin snips. Mine over lap as in the picture but since our openings are larger than his you need to make sure it covers on the top and bottom evenly. Then you'll be folding the edges down, this will also help keep them in place. As for the mounting tabs I cut holes for them to poke thru instead of cutting around them. Also you won't be cutting the hole in the mesh as shown as that's access for the Dakota's hood latch.
By folding the edges down as previously mentioned it'll allow for the black frame to snap in as it did before you may need to use a flat head screw driver tohelp bend the dges more tightly and to push down on the black frame for it to snap in
Old 06-09-2010, 05:34 PM
300 Addict's Avatar
300 Addict 300 Addict is offline
Vehicle: Chrysler 300
Trim Level: Touring
Color: Satin Jade Metallic
Rep:317
300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough300 Addict is a jewel in the rough
That looks sweet man! Love the look! Rep point to ya!
