Old 06-09-2010, 07:24 PM
THE TALLIT MAN's Avatar
THE TALLIT MAN THE TALLIT MAN is offline
THE TALLIT MAN is on a distinguished road
Exclamation Any DIY on removal of stock radio with pics for 2005 Ram
I have searched everywhere on this forum and could not locate one single DIY ; Do it yourself thread on how to remove the factory radio from my 2005 RAM 1500 Quad Cab... its crazy but i cant find a DIY for this task.
THE TALLIT MAN
2005 Anthracite Black, 20's, Kenwood 600W w/ 10" Infiniti Kappa Subs
Old 06-09-2010, 07:29 PM
Rep:1625
Sorry man, I posted a couple links on another thread where you asked this & I didn't realize you had a 05.
Old 06-09-2010, 07:31 PM
I just dont want to break the dash... i just cant figure out how to get the radio out.
THE TALLIT MAN
Old 06-09-2010, 07:32 PM
Rep:1885
WARNING: On vehicles equipped with airbags, disable the airbag system before attempting any steering wheel, steering column, seat belt tensioner, or instrument panel component diagnosis or service. Disconnect and isolate the battery negative (ground) cable, then wait two minutes for the airbag system capacitor to discharge before performing further diagnosis or service. This is the only sure way to disable the airbag system. Failure to take the proper precautions could result in accidental airbag deployment and possible personal injury or death.
  1. Disconnect and isolate the negative battery cable.
  2. Remove the steering column opening cover (See below). CAUTION: When servicing the instrument center bezel, use tape or another suitable material to protect the cup holder and ash receiver from cosmetic damage.
  3. Open the ashtray and the cup holder.
  4. Remove the screw (3) that secures the instrument panel center bezel (2) to the instrument panel (1).
  5. Using a trim stick C-4755 or equivalent, disengage the retainer clips that secure the instrument panel center bezel to the instrument panel.
  6. Disconnect the wire harness connectors and remove the center bezel from the vehicle.
REMOVAL
  1. Remove the two screws (1) that secure the bottom of the steering column opening cover (2) to the instrument panel.
  2. Using a trim stick C-4755 or equivalent, release the two retainer clips that secure the top of the steering column opening cover to the instrument panel and remove the cover.
  1. Disconnect and isolate the battery negative cable.
  2. Remove center instrument panel bezel (See above).
  3. Remove radio mounting fasteners.
    CAUTION: Pulling the antenna cable straight out of the radio without pulling on the locking antenna connector could damage the cable or radio.
  4. Disconnect the antenna cable by pulling the locking antenna connector (2) away from the radio.
  5. Disconnect electrical harness connector.
Old 06-09-2010, 07:43 PM
THIS IS AWESOME.... where did you find this stuff... Just what i needed... thank you.
THE TALLIT MAN
Old 06-10-2010, 12:16 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
u want a video or your good here a video
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
Old 06-10-2010, 04:46 PM
Wrkinprogress's Avatar
Wrkinprogress Wrkinprogress is offline
Vehicle: 2005 Dodge Ram 1500
Color: Charcoal
Wrkinprogress is on a distinguished road
this is easy.. to shorten all those diagrams, simply grab the knob that looks like a coat rack almost on the passenger side, and pull, work your way around popping out the clips, and tahdah!
Then remove the 4 screws holding in the radio, unplug the harness and antenna wire, and your set!
diy, diy radio removal
