Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Mod Zone - Custom Dodge Ram Mods - Dodge Ram Performance > Custom Dodge Ram Performance Mods - Engine - 5.7 HEMI V8
Old 06-11-2010, 12:29 PM
GPGT1 GPGT1 is offline
Vehicle: 2008 Ram
GPGT1 is on a distinguished road
Default Porting The Throtle Body
I was wondering if anyone has attempted this on their trucks? I havn't really looked at it too much but was wondering how the computer would compensate or would it need a good tune?
Old 06-11-2010, 07:54 PM
chefred112's Avatar
Vehicle: 2005 Dodge Ram
Rep:656
im using a ported tb on mine. the pcm has adapted to it plus im runnin a custom tune anyways which accounts to the bigger flow velocity
Old 06-12-2010, 10:08 AM
ram2487's Avatar
ram2487 ram2487 is offline
Vehicle: 2016 Dodge Ram 3500 Mega Cab
Rep:37
ram2487 is on a distinguished road
how much of a difference does porting do to in regards to the rest of the motor?
2011 2500 6.7l Mega Cab Laramie 4X4
Old 06-12-2010, 12:37 PM
Resident Technician
Rep:1915
Are you asking for actual HP numbers? There are going to be some variables involved with that.
Old 06-12-2010, 02:06 PM
ram2487's Avatar
Rep:37
no not exactly but maybe a percentage range?
Old 06-12-2010, 02:12 PM
Resident Technician
Rep:1915
Bear in mind that the bigger throttle body will work better for making top end HP whereas the smaller size will lend itself to making more torque. I don't know that going much bigger would benefit you if you don't plan on changing cams.
Old 06-12-2010, 04:31 PM
doz doz is offline
Vehicle: 2014 Dodge Ram Crew Cab 4x4
Rep:76
doz will become famous soon enough
I wouldnt think of a ported TB until you ATLEAST get headers. Even then, I dont think youd see noticeable gains until you added headers + cam at the minimum. Some people might say itll help, but like Remerson said, youll lose low end torque for minimum higher RPM hp, definitely not worth it IMO.
Id say your money and invest in headers. They are showing about 20hp improvement over stock manifolds, much better bang for the buck.
2015 Camaro 2SS/RS/1LE
Old 06-12-2010, 04:36 PM
Resident Technician
Rep:1915
Definately. An engine is just a big air pump and getting rid of the point of most restriction is the name of the game. Factory manifolds are usually the best place to start.
Old 06-12-2010, 08:47 PM
moparmike07's Avatar
moparmike07 moparmike07 is offline
Vehicle: 07 dodge ram 1500
Trim Level: st
Color: silver
Rep:68
moparmike07 will become famous soon enough
correct once headers you should see a bit improvment
2007 dodge ram 1500 quad cab 4x4 5 percent tint all around 35 percent windshield, ported tb, diablo sport, arh headers, magnaflow dual exhaust, magnaflow y pipe, krc210x cam,nitrous,CNC ported head. 4.56 motive
