Old 06-11-2010, 09:05 PM
RFarruggia's Avatar
RFarruggia RFarruggia is offline
Vehicle: 2010 dodge Ram 1500 ST
Color: Black Metallic
Rep:17
RFarruggia is on a distinguished road
Default 2010 dodge ram 1500 (rims and tires)
Hi everyone, i would like to ask you oppinion on something. what are the best offroad tires and rims for this truck they must be good in snow sand and mud?its the 2010 dodge ram 1500. all comments are appreiated and i hope to get a new set of rims and tires soon thanks for responding.
5.7HEMI 4x4 Leveling Kit 8K HIDs 20%Tint Front 5%Tint Rear Trailer Break Remote Start Tonneau Cover
Old 06-11-2010, 09:23 PM
Rep:1625
Welcome to the forum! There are plenty of options for tires: Toyo Open Country M/T, Nitto Trail Grappler, etc. Obviously, the bigger the size, the bigger the price. Were you thinking about running 35s? As for the rims, I'd look at 17 or 18 inch rims for offroading.
Old 06-11-2010, 09:40 PM
RFarruggia's Avatar
Rep:17
yes i was thinking 35s. and do you think i would need to lift my truck for these tires or i should be good on clearence and no rubbing?
Old 06-11-2010, 11:37 PM
Rep:1625
You might want to look into a leveling kit up front, that way you'll have plenty of room. There are a few folks on here with leveling kits and 35s. Here's one:
http://www.ramforumz.com/showthread.php?t=49151
Old 06-11-2010, 11:39 PM
ScatPak07's Avatar
Rep:970
I would agree and say the Toyo Open Country MTs. If you want to get 35" tires I would really suggest lifting it a little, even a leveling kit. If you stuff 35" tires stock it looks kinda half ass in my opinion. Also if you are getting rims get a negative offset, that will pop the tires away from the truck. That will help with any rubbing issues that you may have had.
Old 06-12-2010, 01:09 AM
RFarruggia's Avatar
Rep:17
thanks for the advice i was thinking of getting helo 18 inch with some beefy tires do you think these rims are good for what i am going to use it for. and i have picked rims but not tires yet. i appreciate all the help!
Old 06-12-2010, 01:21 AM
brad12kx's Avatar
brad12kx brad12kx is offline
Just some guy in Canada
Vehicle: 2010 Ram 1500 QC
Rep:2581
Consider the BF Goodrich All-Terrain T/A tire.
It is a respectable off-road tire, very good in snow, long lasting and much quieter on paved highways than most in it's class.
It is NOT a serious off-road tire, but an excellent all-around tire with an off-road personality.
brad
Interested in one of my mods?
Old 06-12-2010, 02:01 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Well all depends on what your going to use this vehicle for, slight offroad such as gravel or small mud holes, or desert areas are fine, a great all season will work or a mud tire...your choice! Toyo M/T's are highly recommended same with wheels stick around 17-18" as you will spend alot less!
As for 35's if you plan to keep the driving mild with a level you should have no problem with fitment or slight rubbage, but if you plan to wheel the vehicle a little harder, a more sever angles, you will lose alot of travel having such a big tire stuffed under the wheel well! so maybe using a small size would be beneficial!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-12-2010, 12:11 PM
RFarruggia's Avatar
Rep:17
thanks , i will take all this into consideration . and to answer i will need to have tires that are great in the snow because i live in New York, also be good on sand because i am getting the beach permit and will be driving on the beach with the truck.
