07 Ram lift - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Old 06-12-2010, 10:14 AM
BigDaddyDodge32 BigDaddyDodge32 is offline
Vehicle: 2007 Ram 1500 Quad Cab 4x4
Color: Black Metalic
BigDaddyDodge32 is on a distinguished road
Default 07 Ram lift
Need a little help,
I would like to do 2" lift in the rear and a 4" in the front and still keep it pretty level... I would like to hear what you guys have to say and need to know where to get the suspension from? I was reading a little bit and saw the belstein shocks where good... If you can let me know what kit i could buy...
P.S. Can you also let me know how the ride is with the belstein shocks, because my truck very bumpy????
Hit me up...
Old 06-12-2010, 10:19 AM
Bilstein's will quite the ride a bit (soften it) but an empty truck is gonna be a bit bumpy in the rear. Also, you may find your tires are inflated to max pressure. I'd back them down a bit for a better ride.
As far as a leveling kit, there are a lot out there but one of the best is Daystar, IMHO. They make good stuff and stand behind it.
As far as the dimensions, if 2" in the rear and 4" in front levels out the rake, that's fine. I'd start talking to some local shops.
Old 06-16-2010, 06:25 PM
wetcoast wetcoast is offline
Vehicle: 2008 Ram 1500 QC 5.7 4x4
Trim Level: SLT Big Horn
Color: Grey
Rep:22
wetcoast is on a distinguished road
Originally Posted by BigDaddyDodge32 View Post
Need a little help,
Hit me up...
You'll never do a 4" up front without different spindles. I just put a 2.5" procomp in the front and just about killed myself getting the ball joint on the upper control arm back into the spindle. I had to use spring compressors and a floor jack under the lower control arm to get the spindle close to the UCA.
Wife's truck, 33x12.5x20 Toyo MT, Trinity
Old 06-17-2010, 01:08 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Spindles will only work on a 2X4, if he has a 4x4 he will be in for a whole new ball game...trying to get 4" of lift in the front without lowering the front differential is going to put a very severe angle on the cvs and the control arms (will wear the balljoints) so i am going to say it is not in your best interest trying to go up 4" in the front without lowering the front diff!
That is why you can get a 2"-3" level kit and then the next step is 6" suspension!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 06-17-2010, 11:39 AM
Color: Grey
Rep:22
Sorry,
I'm new to lifting trucks and can only speak from the experience I had with a levelling kit. I see how you would need to lower the front diff to lift the front more that 2.5" but don't I see replacement spindles (Steering Knuckle) in this picture of a 6" lift??
http://www.explorerprocomp.com/PDFs/is/56746B.pdf
Old 06-17-2010, 08:57 PM
Ruffian11's Avatar
Rep:140
When lifting vehicles the only time you need spindles is on a 2 Wheel Drive truck as the front axles are not live!!
On a 4x4 you have the steering knuckle, the center is the hub assembly will be there with the cv joint going through that to drive the wheel....there are no spindles on a 4x4, thus there would be no need to put drop spindles on cuz you can't...spindles are a cheap and easy way to lift or lower a 2 wheel drive truck, 4x4 are alot harder and more expensive to lift!!
Old 06-17-2010, 09:09 PM
Color: Grey
Rep:22
Sorry, I guess I minced terms. I originally meant to say that the "steering knuckle" would need to be replaced because there's no way the stocker could fit with a longer strut.
Old 06-17-2010, 09:10 PM
Color: Grey
Rep:22
BTW, Where in Vancouver are you?
Old 06-17-2010, 09:46 PM
ScatPak07's Avatar
Rep:970
I have the Bilstein 5100s in my truck on the 4 corners. I love those shocks they are great! They also handle the tires better too. I loved the ride after I installed the shocks!
There are kits out there for 4" lifts. If you want to go the cheaper route you can do the Bilstein 5100s and raise the truck in the front 2.5" and then get a block for the rear. Once you have those you can get a 3" body lift. Zone makes the best body lift out there since it actually makes the truck look good haha. I have a 1.5" block in the back of my truck and it sits almost level with the 2.5" up front.
It would be better to go with a suspension lift but I thought I would give you an alternative. That suggestion would give you a 5.5" lift rather than a 4" for like half the price.
If you go to Zone's website I think they have a 4" lift for your truck as well.
Old 06-17-2010, 09:52 PM
Color: Grey
Rep:22
Cool. I totally forgot about a body lift.
