94 Automatic Overdrive doesn't work - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 2ND Generation Dodge Ram 1994 to 2001 Dodge Ram Trucks > Powertrain > Cummins Diesel Specific Topics
Old 06-12-2010, 10:49 PM
coyote94yj coyote94yj is offline
Vehicle: 1994 Ram 2500 4x4 Cummins
Trim Level: Laramie SLT
Engine: 1994-1995 359ci (5.9L) Cummins 12-valve Diesel I6 175hp 420lb/ft(manual), 160hp 400lb/ft(auto)
Rep:47
coyote94yj is on a distinguished road
Default 94 Automatic Overdrive doesn't work
Anyone know why my truck doesn't shift into overdrive at all? I just bought it on Monday with this problem so I don't know what happened. I tried pushing the OD Off button and it seems to work. It lights up when I push it once and then goes out when I push it again.
Any ideas guys?
Old 07-25-2010, 08:36 AM
mlrtym's Avatar
mlrtym mlrtym is offline
Vehicle: 1994/98 Ram 2500
Trim Level: SLT Laramie
Color: Flat Black
mlrtym is on a distinguished road
is the "trans temp light" lit? if it is, the computer will not allow it to shift into OD. it is the only electronic part of our transmissions. if it is not lit, then just confirm that the bulb is good. there is a sensor on the oil line going to the rad, front left corner of the oil pan. a bad sensor was my troubles - but mine was intermittent.
hope it helps
Brian
It is better to let one think you a fool, than to open your mouth and remove all doubt.
