Go Back   DODGE RAM FORUM - Ram Forums and Owners Club! - Dodge Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 3RD Generation Dodge Ram 2002 to 2008 Dodge Ram Trucks > Electrical
tonneaucovered.com
Old 06-13-2010, 12:31 PM
Tonatom Tonatom is offline
Vehicle: 2003 Dodge Ram 4.7L
Tonatom is on a distinguished road
Default 2003 Dodge Ram 1500, No Gauge Cluster lights and No Start
Key goes in to full start and back to run spot but lights in cluster etc do not come on.
All accecories like lights and a/c work.
The steering wheel does not lock in position at all when in Park.
I am thinking bad computer, but I can not do the key dance to check codes or anything.
Truck has also 2 times completely shutdown while driving at over 80km/h almost like an electrical glitch hit the truck and powered everything down. But it would start back right up and no codes were displayed on dash.
Help me out please, need truck ASAP.
* Thanks for helping out a new guy, living in Southern Ontario.
Old 06-13-2010, 12:48 PM
Welcome to the forum and sorry for your troubles.
Start with the easy stuff. Check all your battery connections (+, -, starter, ground). Then check the connection to your computer.
Sometimes it's just a corroded or loose connection.
Old 06-13-2010, 01:14 PM
Resident Technician
Rep:1911
The fact the column won't lock makes me think you should be checking the lock cylinder/switch assembly.
Old 06-13-2010, 01:19 PM
Rep:1625
Welcome to the forum!
Old 06-13-2010, 01:29 PM
Dang...I missed that sentence there. So there's a circuit tied to lock that disables start?
Old 06-13-2010, 03:57 PM
Welcome and don't forget to stop by the newbie section and introduce yourself .
Old 06-13-2010, 06:00 PM
So, I went out and check ECU connections and all four clips were okay, no burns or corrosion.
-checked steering column for loose connections or corrosion, no problems there.
-Found out the key can be removed in any position from acc to Start.
-Steering wheel still not locking in position, but I also read on a site the automatics do not have steering wheel lock? I don't know it that is true.
-When you open the door the Odometer and trip calculator still show up on the gauge Cluster but when you turn the key it disappears and doesn't come back.
We get power to all accecories and lights in the acc and start/run postions but still no power to the gauge cluster/odometer.
How do I remove the ignition cylinder to check the ignition switch? Anyone have a detailed description?
Old 06-13-2010, 06:23 PM
Resident Technician
Rep:1911
REMOVAL
The ignition key must be in the key cylinder for cylinder removal.
  1. Disconnect negative cable from battery.
  2. Remove upper and lower covers (shrouds) from steering column.
  3. Place shifter in PARK position.
  4. A retaining pin is located at side of key cylinder assembly.
    1. Rotate key to RUN position.
    2. Press in on retaining pin while pulling key cylinder from ignition switch.
1 - KEY 2 - KEY CYLINDER 3 - RETAINING PIN HOLE
Old 06-13-2010, 06:31 PM
Thanks remerson! I am going to try and replace the ignition switch and see if that is the problem, cheaper than a tow to the dealership.
Old 06-13-2010, 06:40 PM
Resident Technician
Rep:1911
Have you checked it with a test light to make sure all the appropriate circuits have power?
