09 ram aux power outlets not working? - DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum
Go Back   DODGE RAM FORUM - Ram Forums & Owners Club! - Ram Truck Forum > Dodge Ram Forum - Help Zone - Dodge Ram Problems, & Solutions - Maintenance & Repair > 4TH Generation Dodge Ram 2009+ Dodge Ram Trucks > Electrical
Old 06-13-2010, 03:03 PM
fishin buddy fishin buddy is offline
fishin buddy is on a distinguished road
Default 09 ram aux power outlets not working?
went to hook up my new radar detector to one of my aux outlets and it didnt work ,so i tried the next one same thing.Tried all 3 in truck and none work.I checked and repalced fuses all seems alright but still no power. What else can I check or what is causing this?
Old 06-13-2010, 03:18 PM
Resident Technician
Rep:1915
Try plugging in a phone charger or another accessory and make sure it isn't a problem with the radar detector.
Old 06-13-2010, 03:20 PM
Rep:2968
on mine, the 115v is controlled by the ignition key & button above the climate control just to the right of the emergency flashers
the cigar lighter by the shifter is controlled by the ignition key
if you have the full console, the outlet in the top box is always energized i believe, i use that one for my cell phone charging, when i don't use it, i use the 115 v cell phone adapter
Old 06-13-2010, 03:54 PM
radar works in other vehicle so thats good, tried radar with vehicle running and not and still no juice. could somethign be unplugged somehwere ?
Old 06-13-2010, 04:03 PM
Resident Technician
Rep:1915
Something unplugged doesn't explain why all 3 seem to be inoperative. Did you try a different accessory in your truck yet?
Old 06-13-2010, 05:48 PM
yep tried a cellphone and no go either also my compass is just showing 2 blanks no direction i noticed.
Old 06-13-2010, 06:03 PM
Resident Technician
Rep:1915
I have yet to find anything that might be causing this since some of the outlets are bettery fed and others ignition fed and they don't seem to share any common connections. Your best bet is to take it in and let the dealer look at it.
