Old 06-25-2010, 01:46 AM
GPSHSLAX's Avatar
GPSHSLAX GPSHSLAX is offline
Vehicle: 2009 Ram 1500
Trim Level: ST 2X4
Color: Bright Silver Metalic
Rep:236
GPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura aboutGPSHSLAX has a spectacular aura about
Default Induction system cleaning
Been away for a while but I'm back ... with a question.
I've been having an intermitant issue with hesitation while accelerating and had my '09 in at the dealer to have them check it out. They couldn't reproduce the problem and I have no codes in the system so I'm out of luck on that for now (but I'll take suggestion if you guys can offer any).
In any case, while they were investigating, one of the services managers drove it home (I gave him permission) and said he got an idle undershoot on his way in this morning. They recommended an induction system cleaning (to the tune of about $130) to make sure the throttle isent dirty. Now I just went and picked the truck up for the time being, but I wanted to know if anyone could offer me specific instruction on this process for the '09 4.7L engine. As best I can tell it basicly involves removing the filter housing and spraying a good quallity cleaner into the trottle body while the truck idles.
I just want some reasurance before I step up to the plate. Anyone who has done this want to step up to the plate?
Mods: Thule Xsporter 422XT bed rack, Underrail Rhinolining, MOPAR class IV Hitch, DIY CAI, Aero Turbine 3030.
Future Mods/Wishlist: Tuner, Daystar Comfort Ride 1.5" Leveling kit, Nerf Bars, Police style push bumper with light guards, KC or Thule trail lights, HID projector lights.
Old 06-25-2010, 02:18 AM
Rep:1885
First of all do NOT use throttle body or carb cleaner. Only use brake parts cleaner because it won't harm the ETC. Remove the air inlet tube and with the engine off, open the throttle blade as needed and clean it out with the brake cleaner and an old toothbrush. Once it's clean, put it all back together and fire it up and let it run until it's idling smoothly again and you're done.
Old 06-25-2010, 09:26 AM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
Yikes!
Thanks Randy. This is why we ask first. Do you have any more details on what exactly I should be doing. Some have said to remove the throttle body (but I don't want to get into that if I can avoid it (if it need be done that way I may have the dealer do it).
You have peaked my curiosity now. What do the other cleaners do that the brake cleaner won't? I know the excess of the other cleaner will combust in the engine, what about brake cleaner? Much much do I need to worry about it dripping into the TB?
I had been reading up on cleaning with Seafoam or the like so now it's a whole different ball game. If you have the time I would really appreciate instruction with lots of detail.
Again thanks for your quick reply and warning.
Old 06-25-2010, 09:29 AM
Rep:1885
Removing the TB isn't necessary except in the worst cases. The reason Chrysler says to use brake parts cleaner is because TB or carb cleaner can infiltrate teh ETC and wreak havoc on the electronics. TB/carb cleaner is fine for the older cable operated throttle systems. Just follow the steps in my first post and you'll be fine and save a good chunk of money.
Old 06-25-2010, 09:37 AM
GPSHSLAX's Avatar
Trim Level: ST 2X4
Rep:236
On another note. Does that diagnosis sound correct to you? Idle undershoot due to dirty throttle? I've never noticed the undershoot to begin with (and I'm usually pretty observant). Also I've only got about 15,000 miles and I've never driven in any particularly dusty, dirty conditions. It's never been off a paved road for example.
Old 06-25-2010, 09:45 AM
Rep:1885
It's certainly possible and for what it will cost you to do it yourself, it's worth a shot.
Old 06-27-2010, 11:20 AM
blacdog06 blacdog06 is offline
Vehicle: 2006 dodge ram 1500
Color: light kakhi metallic
blacdog06 is on a distinguished road
Default ?
im kinda having the same problem with my 06 ram with the hemi, every now and then get a lil rough idle but no code. so will any brake parts cleaner work? it wont hurt anything to open the throttle plate will it??
Old 06-27-2010, 11:25 AM
Rep:1885
I prefer the chloronated brake parts cleaner. Opening the throttle plate is ok, just make sure the ignition switch is turned off.
Old 06-27-2010, 11:27 AM
Rep:1885
For the bulliten on ETC cleaning, click on this link. http://www.ramforumz.com/showthread.php?t=46764
Old 06-27-2010, 12:03 PM
what brand is chloronated? would crc or super tech brake cleaner work??
