Old 06-17-2010, 01:32 AM
Ruffian11's Avatar
Ruffian11 Ruffian11 is offline
Vehicle: 2005 Dodge Ram 1500
Rep:140
Ruffian11 will become famous soon enoughRuffian11 will become famous soon enough
Being that you are going with such a low profile you going to have a small diameter then stock! and i have seen people run 305/55/20 without rubbing...so i think it will be safe to say you won't have any issues, as long as your not lowered or anything!
2005 SLT 1500 5.7L Hemi
5" Rough Country Lift, Procomp 8101 20x9 Rims, K&N CAI,Flowmaster Exhaust Cat-Back Dual Exit, 325/60/20 BFG KM2, Tonneau Cover, Bedlined, Grill Hella 500's!
Alpine CDA-9887 Headunit, Twister 300 Amp, Dual 10" MTX Thunders, Thunder Form Box
Old 03-31-2011, 01:12 PM
cyberpine cyberpine is offline
Vehicle: 2010 Dodge Ram Quad Cab Hemi
Rep:53
cyberpine will become famous soon enough
Originally Posted by srtsir View Post
Do you have any pics of your tires??
@wrk, you lifted? spacers? what year is your truck? got a pic of that? who makes 325/60/20.. or did you mean 325/50/20?
The word is 305/55/20 on stock 20x9s (+20mm) on a 4th gen (2008+) will rub some on the sway bar at full lock.
305/50/20 Mickeys would be slightly shorter than stock (275/60/20) and the 305/55s, but 2 inches wider than stock! I wonder if and and where that might rub. The Mickey tompson specs say 9 inch is wide enough and I kinda like that retro fat look.
I've been unable to find a single person to confirm or deny this combination. Might prove to be an expensive test.
Thanks.
http://www.cyberpine.com
2012 Red Ram 1500 Hemi Regular Cab.
** PLEASE HELP .. Can I run 18x9 -12mm offset 4.5 Backspacing with 325/60/18 on a stock (no lift no level) 2wd 4th Gen RAM w/o rubbing? PLS MSG ME!
Old 03-31-2011, 02:35 PM
GeauxHunting's Avatar
Rep:1338
Originally Posted by City Slicker View Post
Here's one for now:
Anyone know what kind of tail lights those are??
Dillon-aka, The Little Kid
Old 03-31-2011, 03:15 PM
BlackRamHemi's Avatar
Vehicle: 2010 Ram RCSB 4x4
Rep:554
Thanks.
LOL, He has a 3G 2005 Ram
...every members ride is listed on the top right corner of each post.
a 325/60R20 is a 35"x12.5" and he likely has a lifted or leveled 4x4
Here's a 4G Ram running a 35"x12.5" Mickey Thompson tire on stock 20" chrome wheels but he's a lifted (level kit) 4x4 ,
he has wheel spacers and he says they rub the sway bar at full lock.
Get some 1/4" spacers and you're going to be fine. Try to fit them without first, if they dont rub the A-Arm your good!
if they do rub put your spacers on and just dont crank the wheel all the way when you do a sharp turn.
as mentioned before, even a stock size tire can rub the sway bar on a 2WD 4G Ram...but it wont hurt anything, jeeesh it's just a bent piece of round bar
worst you can do is rub the paint off and it will never damage the tire.
Old 03-31-2011, 03:29 PM
Rep:554
http://www.gorecon.com/
Old 08-12-2011, 08:12 AM
Rep:53
Bump back on this topic..
@City, what size tire is that on the black 4th gen quad. Looks like 305/50/20.
I'm still thinking a 325/50/20 with a 1/2 inch wheel spacer will work with no rub on a 4th gen 2wd stock height. Just worried about how much meat I will have on studs. Someone said I might get 8 full turns and 5 should be enough. Stock gives me almost 14 turns.
Old 08-15-2011, 04:20 PM
Twin4573's Avatar
Twin4573 Twin4573 is offline
Twin4573 is on a distinguished road
What the best price on the Cooper Zeon LTZ tire for a 305 50 20 tire?
Old 08-15-2011, 04:29 PM
RedRam10's Avatar
RedRam10 RedRam10 is offline
Color: Inferno Red Pearl
Rep:743
Great information and something I will be watching as the year progresses as I'll be hunting tires before the next snowfall.
Old 09-13-2011, 07:11 PM
blackram blackram is offline
Vehicle: 2009 Ram 1500
Rep:12
blackram is on a distinguished road
I'v got a 2009 2wd ram 1500 Big Horn Crew. I put 305/50/20's on my stock alloy wheels (sliver, not chrome). They are General Grabber AT's. They rub at full lock on the sway bar. I tried 1/4" spacers with no luck. So I stacked up double 1/4" spacers just to see if it would be helpful to go with 1/2", but it still did not work for me. If you are thinking about running this size street tire, you actually might not rub. My tread pattern wraps around the sidewall and the tread is like a 1/2" deep. Street tires might be alright.
09CC4x2 CST 4+1 Front, 20x9 Fuel Nutz 295/60 Grapps, Black Heads+Tails, CAI, Predator, Custom Exhst
Old 09-13-2011, 07:13 PM
Rep:12
Also, I had the tires put on before I installed a 2" truxx level kit. The level kit did not affect how much the tires were rubbing! There was no noticeable change between stock and leveled height as far as rub goes.
